Single (and Two) Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Apr 16, 2017 at 12:01 PM
    #301
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    What are you talking about? That driveshaft is set up exactly like the driveshaft of most long wheel base 1st generation Tacomas. The slip joint was moved down to the rear differential (where most reside anyway on other trucks). There's nothing wrong with his driveshaft.
  2. Apr 16, 2017 at 12:09 PM
    #302
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    You are right. I'm deleting that pos pos
  3. Apr 16, 2017 at 7:12 PM
    #303
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    @1MK Cut his out. Maybe he can comment.
  4. Apr 17, 2017 at 9:14 AM
    #304
    klikboom
    klikboom Well-Known Member
    SNOHOCO
    Taco
    Been two weeks with the 4" single piece. I did chop the center section and yes you definitely have to cut it or remove the whole member by drilling out frame rivets on the sides.
    I can report, "vibes-b-gone."
  5. May 16, 2017 at 5:41 AM
    #305
    Bluesjam
    Bluesjam Well-Known Member
    Paul
    2020 Tacoma SR Magnetic Grey Double Cab 4x4
    All of this is so confusing, the more I read the more confused I get.
    Key-Rei and Crosis like this.
  6. May 16, 2017 at 8:55 AM
    #306
    descartesairplnne
    descartesairplnne Well-Known Member
    Justin
    Truckee CA
    2014 Tacoma TRD
    redneck pinstriping, various stickers, not 1 but 2 glade air fresheners because I fart a lot.
    Ok I'm not bragging but just an observation. I've just installed LR-UCA, Icon extended coils, deaver U402 exp pack 3" lift and fox VS20 rear shocks. I was fully expecting to get the dreaded vibes this thread suggests and nothing nada zip zilch. 0-90MPH is smooth as butter. This leads me to believe there must be a magic combination in the suspension build that just works. Rims and tires are TRD Bronze 16" and Treadwright Warden 285x75/R16.
  7. May 17, 2017 at 11:41 AM
    #307
    evskie53
    evskie53 The Problem Child
    Denver
    2011 DCSB Sport
    Do you have a double cab short bed?
  8. May 17, 2017 at 12:52 PM
    #308
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    I have a DCSB
  9. May 24, 2017 at 3:20 PM
    #309
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Subscribed because this is now on my to do list
  10. May 27, 2017 at 7:31 PM
    #310
    logikoone
    logikoone Well-Known Member
    Dallas
    long beach , ca
    trd off road
    Been thinking about the single piece driveshaft for a while .
  11. Jun 21, 2017 at 1:24 PM
    #311
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    When I first read the original post (along with all the following post) on this thread, it made sense (at the time) on the fact of the vibration issue that has plagued the Tacoma extended cab with a, now, known issue.
    This interested me and I started to research and dig more into the comparison of "straight drive shaft" and "OEM drive shaft in two parts" and well after calling several places that specialize in custom drive shaft for all vehicles, cars, trucks, rig's, tractors, etc. and explaining the vibration issue that the Tacoma has I kept getting the same response.
    I was told that "yes" you can change the OEM drive shaft to a "straight drive shaft" but that there would still be a considerable amount of "vibration" when driving at various speeds.
    I asked for a detailed explanation on this and basically I was told that the main vibration problem with Tacoma's had to do with the rear differential design of the Tacoma along with the drive shaft and possibly other associated components related to the drive shaft and rear differential.
    That yes, vibration would decrease to a certain amount by just swapping out the drive shaft only but that vibration would still be present at various speeds due to the rear differential design and the only way to correct it would be to have the entire differential replaced along with the drive shaft due to its age. Was also told that over a period of time (years) that Tacoma owners would start to encounter this nagging vibration problem and that not just Toyota Tacoma's experienced this nagging vibration problem but that other manufactures as well, Ford, GMC, Dodge, Nissan, etc. because of the rear differential design along with the drive shaft.
    It appears as though that the vibration problem on Tacoma's does not come down to just one "single thing" causing the problem. It appears that it is a combination of "several things". I've posted links to several post that references this as well as a subject concerning, specifically, this particular annoying problem.
    Well that's just my take on this problematic vibration issue that has plagued Tacoma drivers.
    https://www.tacomaworld.com/threads/how-to-replacing-carrier-bearing.260283/
    http://www.tacomahq.com/2645/toyota-tacoma-vibration-issue/
    https://www.tacomaworld.com/threads/i-know-another-bad-vibration-thread.472967/
    https://www.tacomaworld.com/threads/03-tacoma-vibration-issue.485544/#post-15435788
  12. Oct 10, 2017 at 1:55 PM
    #312
    DrFunker
    DrFunker Well-Known Member
  13. Oct 10, 2017 at 1:58 PM
    #313
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Without going through all the pages is this available for the DCLB as well??
  14. Oct 10, 2017 at 1:59 PM
    #314
    DrFunker
    I am sure it is. But, as Joe said, it would probably mean the shaft hanging a bit low.
  15. Oct 10, 2017 at 2:00 PM
    #315
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I don't need to worry about that Brother, only go over leaves at most
    DrFunker[QUOTED] likes this.
  16. Oct 10, 2017 at 2:00 PM
    #316
    DrFunker
    True.
  17. Oct 15, 2017 at 10:50 PM
    #317
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    Do you know what flange that is that you used for the DC? Part number and company. Is it a custom spline or did it go to the factory spline?
  18. Oct 18, 2017 at 8:10 AM
    #318
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    So I read through most of this thread..... My previous Taco was a 2005 4x4 TRD Offroad Access Cab... Dakar Leafs, 5100s, OME Coils, leveling spacers, Tom Woods single piece D/S.... The best improvement was the take off from a stop, no more vib...... seemed to accelerate with less hesitation which I attributed to the drive shaft wanting to flail around in the carrier bearing.
    I traded the truck in a few years ago and recently was cleaning out the garage and noticed I still have the oem driveshaft.... driveshaft wasn't the original on the truck, I brought that truck into Toyota at 60k miles for it to be warrantied. I only had that d/s on for 10k-15k miles before going to the Tom Woods.......Actually tried to list in classifieds to no avail, something must have changed where now you need 50 posts to list.... didn't used to be like that because I was able to list in classifieds a couple years ago... I understand why they require 50, but I think it is a bit tedious to post misc comments to dilute threads in order to reach 50, and I read much more than I post.... PM me if interested in d/s...
    Now I have a 2015 4x4 TRD Sport DCLB with OME 885 coils, leveling Spacers, Dakar leafs +1" spacers, 5100s.....I am wondering if many guys have gone to a single driveshaft on the long beds? Or if it is even possible. Thoughts?
  19. Nov 3, 2017 at 8:42 AM
    #319
    SebSA
    SebSA Active Member
    2013 DCSB 4x4 4.0 Auto
    If I install a CV single piece DS I am assuming I need to shim the rear axle so that the differential points at the transfer case. I did not see shimming mentioned in this thread or others I have searched. In fact, some have said "just bolt it on." Can somebody please confirm that I need to shim? Has anyone done this and if so how did u figure the degree of the shim? I was just thinking about measuring the rise, and the distance between axle and transfer case and calculating the angle I need.
  20. Nov 3, 2017 at 8:57 AM
    #320
    ItalynStylion
    Steven
    DFW, Tx.
    I believe I used 2 degree shims on mine with the two piece OEM shaft modified to use a double cardan joint.
