Single (and Two) Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Jul 23, 2018 at 2:43 PM
    #421
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are you guys 'overfilling' the rear differential?
  2. Jul 23, 2018 at 3:36 PM
    #422
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Sorry dude, not criticizing, just trying to find humor in the situation....trust me, been thru all that with my '05.... Eventually gave up....i went to a tom woods single piece and that helped eliminate the shudder off the line, but at 55mph it hummed like crazy...granted this was all 10 years ago, but i i have little faith there is a solution. prior to that I even got toyota to warranty it, new motor mounts and driveshaft.... Nothing seems to work.......
  3. Jul 23, 2018 at 4:28 PM
    #423
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Fair enough. This is a sensitive subject for me today. lol. :)
    I was going to go with the Tom Woods driveshaft, but I was worried about the critical speed issue and long term durability.
    Key-Rei likes this.
  4. Jul 24, 2018 at 10:44 AM
    #424
    ThomasMore66
    Dallas/Fort Worth & Durango
    Obviously.
    EDDO[QUOTED] likes this.
  5. Sep 19, 2018 at 5:24 PM
    #425
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I've got some vibrations after a 2" lift in the rear and I'm strongly considering this single driveshaft option from Tom Woods. I've spoken with both Troy and Josh there and I've since taken the necessary measurements ( and more) to provide to Tom Woods. With this, I have a few questions for everyone:
    - Does the Tom Woods driveshaft start at 3.5" dia. and is this the recommended/typical size that people are ordering with stock FD gears?
    - The Tom Woods website indicates a two joint for lifts up to 3", and a double cardan for higher lifts. I've only read of people getting the double cardan. I'm taking it that since the double cardan can handle twice the angle of a single joint, the double cardan is the safer way to go regardless of the lift height?
    - My additional measurements were to analyze whether the driveshaft would hit the cross member should I hit the bump stop. Under full compression, with a 3.5" DS, I'm a little less than 1/2" away. Since the bump stops are not solid, that little spacing makes me concerned and will likely hit. Of course some, if not all, have cut their cross members. My questions are: Since the success rate of eliminating vibrations with the TW driveshaft is about 90% (per Troy), what if vibrations were not eliminated? Would you then need to weld the cut piece back? Has anyone considered removing the cross member to keep it unharmed?
    I see that the cross member is riveted in and probably more of a PIA than cutting, but being able to re-bolt it back has some value. Additionally, I see that the cross member isn't just for the carrier bearing, but also to support the lines that run along side of the truck. I would think fabricating a mount to support these lines wouldn't be too difficult.
    FYI, I came up with the exact same measurements for A, B, C1, and C2 that ItalynStylion posted for his truck. Mines is also a Double Cab Short Bed (2014). @ItalynStylion thank you for this thread and your help.
  6. Sep 20, 2018 at 5:26 AM
    #426
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    @Musubi3 is there any reason why you wouldn't want to go with a custom two piece drive shaft? It really is the best total solution and doesn't require you to cut the cross member. Just take your old drive shaft to a drive shaft shop and tell them you want a double cardan joint welded in behind the carrier bearing. Great time to put a new carrier bearing on too since they'll have it apart. New u-joints are too cheap to say no to and with that, you should be good.
    Key-Rei and EDDO like this.
  7. Sep 20, 2018 at 11:07 AM
    #427
    Musubi3
    Big Island
    You know, I was just thinking that this morning. I could avoid all this hassle with installing a double cardan there. I was planning to re-read the thread to find out how you did yours again. I agree, it would be the best of both worlds. Does the double cardan joint lengthen the rear shaft and, if so, was it accounted for?
    Originally, did you cut your cross member then add it back in for your current setup?
  8. Sep 20, 2018 at 11:36 AM
    #428
    ItalynStylion
    Steven
    DFW, Tx.
    As I mentioned in my PM, I did NOT cut the cross member.
    And yes, the double cardan adds a bit of length when compared to a single u-joint. However, when the drive shaft shop cuts off the u-joint flange they simply cut a little bit more out of the shaft to compensate for the length change.
  9. Sep 20, 2018 at 2:59 PM
    #429
    Musubi3
    Big Island
    Thanks for the info. Sorry, I was getting confused since you did run the single TW shaft for a bit and the cross member, in general, needs to be cut. I take it that you ran the TW with the cross member intact, but didn't compress the rear much?
  10. Sep 20, 2018 at 3:33 PM
    #430
    ItalynStylion
    Steven
    DFW, Tx.
    That's exactly right. When I had the TW shaft (briefly for about 1 month) I did not do any offroading; just highway.
  11. Sep 20, 2018 at 4:30 PM
    #431
    Musubi3
    Big Island
    One more question for you. You mentioned in an earlier post that your start off vibrations were eliminated with your current setup, however you were experiencing some vibrations at 50 mph. Were you able to address this?
  12. Sep 21, 2018 at 4:19 AM
    #432
    ItalynStylion
    Steven
    DFW, Tx.
    The vibrations at 50 were caused by the single piece drive shaft spinning beyond it's critical speed. There are no vibrations present with the two piece double cardan shaft.
    TAC1 likes this.
  13. Nov 13, 2018 at 2:58 PM
    #433
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    So how many people have gotten the two piece drive shaft with a double cardan joint right behind the stock carrier bearing and are happy??
    TAC1 and MolonLabeTaco like this.
  14. Nov 13, 2018 at 8:23 PM
    #434
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    :yes:
  15. Nov 13, 2018 at 9:00 PM
    #435
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Why did toyota go with a two piece drive shaft rather than one piece? What's the advantage? Just curious.
  16. Nov 13, 2018 at 9:01 PM
    #436
    4wdExplorer
    Orange County, CA
    Better ground clearance with two piece.
    NMTrailRider[QUOTED] likes this.
  17. Nov 13, 2018 at 9:02 PM
    #437
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I went with the Tom Woods single piece recently and I’m happy with the results. Not planning to regear, so I should be good, staying below the critical speed.
    Thanks to OP @ItalynStylion for posting the info.
    TAC1, ItalynStylion[OP] and Biscuits like this.
  18. Nov 13, 2018 at 11:26 PM
    #438
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    88mph?
    TAC1, Norton and loginfailed[QUOTED] like this.
  19. Nov 14, 2018 at 3:47 AM
    #439
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  20. Nov 14, 2018 at 10:49 AM
    #440
    ThomasMore66
    You saw my math in the SC thread. I don't like how low the mph is to reach critical speed. I'm not sold on the one-piece.
    Key-Rei and Biscuits like this.
