Single (and Two) Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Jan 30, 2019 at 6:17 PM
    #581
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Not for a DCLB.
    canadian bum and ovrlndkull like this.
  2. Jan 30, 2019 at 6:18 PM
    #582
    DavisluvsTacos
    DavisluvsTacos GONE FULL-RETARD!
    Beyond the sun
    Yes sir I did it and perfect
    Same year as yours and 4x4
    rmepilot[QUOTED] likes this.
  3. Jan 30, 2019 at 6:21 PM
    #583
    DavisluvsTacos
    Beyond the sun
    I was skeptical and took the plunge and no longer a skeptic that double c is the magic
    ItalynStylion[OP] likes this.
  4. Jan 30, 2019 at 6:22 PM
    #584
    rmepilot
    Rob
    Huntsville, AL
    Best of luck with that, I hope it lasts if you’re lifted.
  5. Jan 30, 2019 at 6:30 PM
    #585
    canadian bum
    canadian bum Well-Known Member
    Alberta, Canada
    2005 SAC DCLB
    Spacer lift with 42s
    I need to keep mine from smashing into rocks as best I can and yeah a one piece on the DCLB is going to be interesting. Definitely only going to run 2 piece on my rig.
  6. Jan 30, 2019 at 6:38 PM
    #586
    rmepilot
    Rob
    Huntsville, AL
    Mines not DC, but I like it so far. I still need to adjust the angles.
  7. Feb 5, 2019 at 10:28 PM
    #587
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    @aleccolin does this list work for dcsb 2wd? I see you were specific on the carrier bearing. Thank you for the hard work print this list together.
  8. Jun 1, 2019 at 12:24 PM
    #588
    deathpunch8210
    deathpunch8210 Well-Known Member
    Josh
    Bakersville,NC
    08 tacoma crew cab
    3in. Rough country leveling kit. Aftermarket headlight & taillights
    Thanks guys for the info
  9. Jun 1, 2019 at 3:14 PM
    #589
    ThomasMore66
    Dallas/Fort Worth & Durango
    Since my vibes are gone, I only catch up on this thread intermittently. After trying many of the things in this thread short of a new DS, I went with a flush and a new valve body. Curious if anyone else has tried this.
  10. Aug 4, 2019 at 7:19 AM
    #590
    bren5279
    bren5279 Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox dual rate 2.5" remote res front coil carriers Fox triple bypass 2.5" remote res front shocks Fox 12" 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.88 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R Method beadlock 17x9 Rims 37" Open country R/T tires Baja fiberglass Front Fenders Baja Fiberglass Rear Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    For those of you running Double Cardan 2 piece shafts, what angles are you running? Is everyone running the Diff Pinion parallel to the Transfer case Pinion?
    Key-Rei likes this.
  11. Aug 4, 2019 at 7:38 AM
    #591
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    boogie3478 likes this.
  12. Aug 4, 2019 at 8:08 AM
    #592
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    :D
    Kolunatic likes this.
  13. Aug 14, 2019 at 11:21 AM
    #593
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Just ordered 4" single-piece from Tom Woods. I guess we'll see how it goes!
    Regearing to 4:10 next month, which, according to Troys calculations, would have been just over the critical speed of a 3.5" driveshaft at 75 mph.
    ovrlndkull likes this.
  14. Sep 2, 2019 at 3:06 PM
    #594
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Driveshaft is in. Also put in 3.5 degree shims. Take-off vibes are 95% gone. If I accelerate hard I still get a very slight vibe, probably axle wrap. But normal acceleration is butter smooth.
    I completely removed the crossmember for clearance.
    I should have done this 2 years ago.
    BassAckwards, TAC1, Kolunatic and 3 others like this.
  15. Sep 9, 2019 at 6:12 AM
    #595
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Threw in the 4.10's this past weekend. There's no noticeable wobble at ~70mph. Seems solid.
    BassAckwards likes this.
  16. Sep 26, 2019 at 2:05 PM
    #596
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    I just ordered Billie 5100’s front and rear to get rid of my space lift. I concede, y’all were right - I should have saved and done billies in the first place. Damn my ignorance and arrogance.
    im about to bite the bullet and buy a Tom woods single piece shaft too.... im sick of this tremendous vibe. Can I just get a good consolation from you guys that it will likely fix my vibration issues? I want to be done with this - shimming and CB drops did nothing and I just want it settled. Tom himself emailed me back saying it doesn’t always fix it but they have had good success... I don’t wanna drop $470 if it’s not pert near guaranteed to fix my issue... any one who can comfort me to take the plunge? Also, does he accept PayPal by chance?
  17. Oct 4, 2019 at 9:34 AM
    #597
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    is there a guide for this? i am looking into doing this. thank you!
  18. Oct 17, 2019 at 12:17 AM
    #598
    TacoBeng8
    TacoBeng8 Well-Known Member
    same as yours
    Totally off topic for a second. I noticed you have black center caps for your TRD beadlock wheels. Where did you find them? I'd prefer that over the shiny ones.
  19. Oct 17, 2019 at 3:05 AM
    #599
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    To confirm the use of a 1 piece I have had a TW 1 piece in my 2009 Tacoma for nearly 6 years and no vibes.
    Its 67.25 flange to flange length and 3.5 in diameter with u-joints both ends (Type B), mounted with the slip end in the xfer case for more protection.
    The existing center carrier mount left after you take the 2 piece out is not in the way of anything. Driveshaft angle does not hang down lower than 2 piece.
    Running rear Dakars about 3" lift and 5100s with stock front springs and the 5100s on 2nd groove from top (about 2" lift). Stock a-arms alignment fine and no steering problems, running 265/70r16 Michelin LTX A/T2s (will be getting 3rd set soon). No gears changed as stock tire size. Full 3/8" steel skids cover all from All Pro and Budbuilt (gas tank).
    No problems here running at any speed or when towing. You can try many things and read about fixes forever on the 2 piece shaft - so good luck.
    TAC1 and Kolunatic like this.
  20. Oct 17, 2019 at 6:30 AM
    #600
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Putting this up again...still curious if the one piece shaft reduces any rotational weight with a 1 piece shaft compared to oem.
