Single (and Two) Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Mar 17, 2017 at 10:18 AM
    #81
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Hmmm, very interesting. I've not heard this before but now I'm a bit worried as I'll be regearing next week which will obviously change my cruising RPM. I've never heard that drive shafts have a "top speed" per se (and I was not informed of this) so this is certainly news to me.
  2. Mar 17, 2017 at 10:27 AM
    #82
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    I'm not trying to scare you, I just think it's something you and others should know. I've been dealing with vibrations for going on 2 years now, and I'd considered a single piece driveshaft until I started talking to shops and reading about how they didn't fix things on TW. I'm not saying your truck is mystically going to self-destruct on the highway, but it's a issue sometimes. If Tom Woods said it was okay, I'd roll with it. As long as they've been building driveshafts, they wouldn't sell it (would they?) if it put someone at risk of major repairs.
    EDDO likes this.
  3. Mar 17, 2017 at 10:52 AM
    #83
    ItalynStylion
    Steven
    DFW, Tx.
    Thanks for the advice Sir. We will see how it feels Tuesday afternoon when I get the truck back from my regear and locker install. I'll take it out on the highway and see how it does at that point!
  4. Mar 17, 2017 at 11:01 AM
    #84
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Ok stupid question, I'm assuming I have to remove my existing drive shaft to get all the measurements?
  5. Mar 17, 2017 at 11:23 AM
    #85
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Thank you for bringing this up. Based on my calculations (31.6" tires, 3.73 gears) the driveshaft is spinning at 3000 RPM at 75.64 mph. 3000 RPM is what their measuring guide calls "expected maximum operating speed". Food for thought.
  6. Mar 17, 2017 at 6:07 PM
    #86
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Please report back. After getting over 4" of lift in the rear I've been getting some nasty take-off vibes between 5-8mph. I'm looking to this driveshaft as a solution.
  7. Mar 17, 2017 at 8:05 PM
    #87
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I have 3* shims and 3/4" carrier bearing drop. I have vibes below 10mph only when accelerating. I believe it is the carrier bearing bushing causing the vibrations. Never really bothered me, I'm well over 4" rear lift.
    If you drive with excessive constant vibrations for a long time, you can wear out the pinion bearings, or the T-Case output bearings, thus making the vibrations worse, and present when you modify your D-Shaft.
  8. Mar 17, 2017 at 8:23 PM
    #88
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    :D That's what she said.
    Diablo169[QUOTED] likes this.
  9. Mar 19, 2017 at 7:44 AM
    #89
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Calling Tom Woods tomorrow to order my one piece double cardan. Tired of chasing this bullshit every week. Was this just simply bolt-on, is there a specific details/tips you would give based off your install? Thanks
    PoweredBySoy and 303tacoma like this.
  10. Mar 19, 2017 at 8:28 AM
    #90
    garyregcab14
    garyregcab14 Well-Known Member
    Garrett
    cincinnati ohio
    2014 Tacoma reg cab 4x4
    light bar, king 2.5 w/remote resi, wheel spacers, magna flow exhaust, wheelers progressive add a leaf, fox 2.0 rear shocks
    my regular cab Tacoma with 3in lift in rear had bad vibrations 50-60mph, finally bought tom woods double cardon and no vibration anymore
  11. Mar 19, 2017 at 8:46 AM
    #91
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Subbed
  12. Mar 19, 2017 at 5:06 PM
    #92
    ItalynStylion
    Steven
    DFW, Tx.
    Bolt on. My current install uses some 2 degree shims on the rear axle (very cheap) and a 3" lift. It fixed the vibrations for me. I'll wait to post a full report once I get the truck regeared tomorrow. I should have the truck back Tuesday night. I say this because I want to see if any vibrations occur due to the shaft having to spin faster due to the shorter ratio in the rear diff. I'll update once I get it back.
  13. Mar 19, 2017 at 5:31 PM
    #93
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    I just watched your video again, and the 42-second vibe looks exactly like the one I have now. A strong pulse that lasts about half a second, just after take-off. This happens even under normal acceleration. I didn't have it when I installed the Allpro leaf packs. But a couple months later I added an AAL, which gave me over another inch of lift, then the vibe started.
    ... well, that's when this particular vibe started. Because lets face it, this drivetrain has given me various vibes since I pulled it off the lot.
  14. Mar 19, 2017 at 7:23 PM
    #94
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Thanks, yeah sounds like I have a similar lift as you. I too have the 3* axle shims. Looking forward to hearing a full report, thanks again
  15. Mar 20, 2017 at 12:20 PM
    #95
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Just ordered my one piece. Spoke with Tom Woods himself. Should be here Friday
    adanfon, nDub, Bobcdn and 1 other person like this.
  16. Mar 21, 2017 at 4:59 AM
    #96
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Hey man, one more question,were you able to reuse the mounting bolts or did you have to get new ones? They told me the flange they use is thicker than the oem flange and I may need
    longer bolts, but I think that was before I spoke with Tom himself, he didn't mention it so I am thinking the other guy might have been confused. Thanks
  17. Mar 21, 2017 at 5:42 AM
    #97
    ItalynStylion
    Steven
    DFW, Tx.
    I reused mine without an issue. They were perfect.
  18. Mar 21, 2017 at 6:36 AM
    #98
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Just to confirm, you ordered it with the exact measurement numbers in Stylion's OP, correct?
  19. Mar 21, 2017 at 6:48 AM
    #99
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Sub'd.
    I have a DC long bed and although I've heard this is just a SB problem, I have read a few instances of LB Tacomas getting this vibe. If it ever happens to me, Im going to order one!
  20. Mar 21, 2017 at 7:42 AM
    #100
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Yes, I took my own measurements but they ended up being identical to Stylion's, so that's what I went with. I didn't need the "A" measurement, Tom said all Toyotas used the same male/female part of the flange at the transfer case and differential. I'll let you know this weekend if I run into any trouble with the install.
    Bobcdn likes this.
