Single battery set ups
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uscg2008, Nov 3, 2013.
  1. Dec 31, 2014 at 12:26 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I'll be interested to see how that particular battery works in your cold weather
  2. Dec 31, 2014 at 4:42 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Deep cycle batteries usually make fairly lousy starting batteries. There are a few hybrid batteries out there but they are a compromise.
  3. Dec 31, 2014 at 5:00 PM
    uscg2008
    uscg2008 [OP] Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    the diehard has 1150cca is that not enough????
    Which one? The diehard or battery pack?
  4. Dec 31, 2014 at 5:16 PM
    OZ-T
    Peter North
    British Columbia
    The Diehard Platinum marine battery
  5. Jan 1, 2015 at 1:10 AM
    uscg2008
    coby
    There a plenty of people running them with good results. I haven't once had a problem on a cold morning. Even without plugging my block heater still turns over easily.
  6. Jan 1, 2015 at 1:14 AM
    OZ-T
    Peter North
    British Columbia
    I opted for the Northstar AGM 27F
  7. Jan 1, 2015 at 5:21 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Here is a general performance (CCA @ 0 degrees F) graphic published by Exide showing the relationship between temperature and performance of a fully charged battery @ 80 degrees F:
    and a general capacity (AH) vs. temperature chart published by Concorde for their AGM batteries:
  8. Jan 1, 2015 at 5:24 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    A starting battery has lots of amps short term a deep cycle has the capacity long term and can take many deep charging cycles, kill a starting battery a few time and you'll be buying a new one. Yes batteries have made quantum leaps over the past several years I hope yours does what you want. The figure to look at is amp hours if you are going to use it for camping.
  9. Jan 1, 2015 at 5:41 AM
    Pigpen
    Dan
    Northwest Montana
    I've been reading all these battery threads, and every time I think I have it figured out I realize I still don't have a clue.
    Ideally, I'd like to run one battery but would be willing to go to 2 if needed. Here in Montana we see a few days to a couple weeks (depending on the year) right around 100 degrees. We also see about the same number of days around 25 below zero. I have a winch and use it, mostly for my forestry and hauling business but also offroading and hunting.
    My OEM battery on my 2012 hasn't started to fail yet, but I know I will need to replace it before too long. Right now I'm torn between getting two yellow top Optimas or the Die Hard Platinum. I would consider other suggestions (red top/ yellow top?)...
  10. Jan 1, 2015 at 3:05 PM
    uscg2008
    coby
    But that's why I got this kind of battery. It has enough power to start the truck every time and the amp hours to last while camping. I have no need for a dual battery set up. it doesn't get down deep in the negatives here on Kodiak. The only reason I got the jumper pack was more for piece of mind and easy of being able to charge phones iPads and laptops, but it'll have the power to just myself or anyone else if the need arise.
  11. Jan 1, 2015 at 3:17 PM
    weazel
    weazel Well-Known Member
    If you have one of the name brand 12v fringe you should be fine with that battery.The fringe does not run all night long, on my diehard group 65 I can run 2 days without starting the truck.
  12. Jan 2, 2015 at 6:38 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The modern RV DC type fridge is very power efficient they do not use rotary compressors have low current draw and far better insolation. The cheap ones with no compressor are power hogs they will kill even a big battery in short order. The down side a good one can cost $500 or more.
