Single battery solar?
Discussion in 'Technical Chat' started by scotthulbs, May 25, 2020.
  1. May 25, 2020 at 3:08 PM
    scotthulbs
    scotthulbs [OP] Member
    Scott
    16 DCSB SR5
    I'm trying to power a 12v fridge, could I wire up a charge controller to a single battery? My thought is to get an AGM with a 100w panel mounted to the roof in hopes that will be sufficient to run the fridge nearly indefinitely. Is this possible?
  2. May 25, 2020 at 3:21 PM
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    It’s possible but probably overkill. If all you’re looking to run is a fridge, a good battery will do that for a few days no problem.
    Naveronski likes this.
  3. May 25, 2020 at 3:27 PM
    scotthulbs
    Scott
    16 DCSB SR5
    Should I be concerned with an agm battery not being properly charged by the alternator? I was thinking that rather than spending $75-$100 for a charger to keep the AGM happy I may as well spend the extra $ for solar and hopefully never have to worry about power.
  4. May 25, 2020 at 3:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Its possible and a good setup if you get a good sized AGM battery. I ran this setup with a 31M northstar in the stock location. Had no issues with charging and running a 50qt fridge but it is my daily driver so having the alternator help with the charging really helps vs a standalone system. I ran the same setup standalone with a 31M and it was much better once i wired it up as the main battery
  5. May 25, 2020 at 3:45 PM
    scotthulbs
    Scott
    16 DCSB SR5
    Great, sounds like I'll try just the battery and see how it works out. If I feel the need to add the panel in the future at least I know I can hook it up without issue.
    Thanks guys
  6. May 25, 2020 at 3:49 PM
    brywebb11
    brywebb11 Active Member
    Bryson
    White Tacoma TRD Offroad Access Cab
    I have a domestic 12v fridge and wanted it to run on solar. I used the Dometic PLB40 as my battery because I got a good deal and I can plug the solar straight into the battery. The PLB40 is a charge controller, battery and DC inverter in one. I also got it on REI when they had 20% off one item. I'm sure there are other deals just like that.
  7. May 25, 2020 at 3:55 PM
    scotthulbs
    Scott
    16 DCSB SR5
    I've looked at the PLB40 but I can't justify the price. Maybe in a couple years prices will come down. It does seem like a great solution though.
