Single cab lift experiences, 5100 settings, vibrations
Discussion in '4 Cylinder' started by tacoma4, May 3, 2013.
  1. May 3, 2013 at 7:21 PM
    tacoma4
    tacoma4 [OP] Well-Known Member
    I'm looking at getting a set of 5100s for my reg cab 4x4. I was looking for peoples experience with lifting the front end. It seems some people go with .85 others 1.75 to level the truck. Has anyone had vibration issues after lifting? I would guess our driveshaft has fewer issues, but the front diff needle bearing is what is making me lean towards staying on stock struts. I dont want to drop money into suspension and have it cause more issues. I will be moving to 265 75r16s at the same time, can anyone comment on the combo of 5100s and larger tires on vibrations or cv wear? Thanks
  2. Sep 10, 2013 at 7:19 AM
    SUMMIT556
    SUMMIT556 FCK Lightbars sponsor
    09 Tacoma SR5 4-cyl
    Bilstein 5100 front, FOX 2.0 remote resi rear, 2in add a leaf, OME 885 coils, magnaflow exhaust, LCE header, Toyo ATII 285/75/r16, fck lightbars, retrofit headlights and more.
    as no one seemed to even reply I have the 5100 up front and the 5125 in back with an AAL and OME 884 coils. I had bad driveline vibrations so I flipped the driveline and its perfect! CV angles are fine same with everything else.
  3. Sep 10, 2013 at 7:22 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    this is what she looks like.
  4. Sep 11, 2013 at 8:09 PM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    I have 5100s all around and the Icon AAL, my 5100s up front are on the highest setting. After install I had a SLIGHT vibe, the alignment fixed it. I was super pleased with the smooth outcome. I chased vibes on my TJ wrangler the entire time I had it. I am nearly ready to order my UCAs, hopefully they will remedy the wandering on the interstate. No regrets here :) Hopefully down the road when I can spare the coin I will upgrade to some nicer coilovers to get a more "plush" ride.
  5. Sep 11, 2013 at 9:07 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Thanks for posting. I was thinking 884's for my 4cyl since there's less weight and your pic confirms that. Looks like a V6 SR5 with 885's. What size tires are those?
  6. Sep 11, 2013 at 9:41 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    those are 245/75/r16. I did the lift with the 884 coils and removed my swaybar so I preloaded the 5100 to .85 and made the truck almost level. I decided to get the lift before tires. 265/75/r16 toyo M/T tires. I also removed my secondary air filter and made a big difference with the 4-cyl. Thanks man I love my Tacoma!
  7. Sep 12, 2013 at 7:26 AM
    Yotabilly
    The Bluegrass
    Any pics of how it sits now, with the 265's and after the coils have had a chance to settle? Also, what do you mean by "flipping" the driveshaft?
    Thanks again.
  8. Sep 13, 2013 at 10:53 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    I don't have the 265's yet I will post a picture of my drive shaft later
  9. Sep 13, 2013 at 3:34 PM
    ffbartlett
    ffbartlett Well-Known Member
    southern california
    2011 Reg Cab 4x4
    tint, bfg's, 5100's, tunnel cover.
    I have 5100s on my single cab 4x4 and I have no issues with vibrations, front is set at the middle setting. nice truck summit.
  10. Sep 13, 2013 at 4:40 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    Thanks man! I love my truck regular cabs are the best!
  11. Sep 13, 2013 at 5:24 PM
    Yotabilly
    The Bluegrass
    It looks pretty good now. The 245's don't really look as small as I thought they would.
  12. Sep 14, 2013 at 1:28 AM
    Ninjayota
    Ninjayota Well-Known Member
    South Texas
    2012 regular cab base 4x4
    Mb 352 wheels, 265/75/16 duratracs
    How much lift did you get with the 884s and the 5100s set to .85? I'm thinking about just getting the 884s. I already have axle wrap issues so I'm thinking of getting the wheelers hd springs and removing a leaf. Don't want too much rake but a little is okay.
  13. Sep 14, 2013 at 4:56 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    If you have no sway bar I would get the 885 coils. The only reason why I put the 5100 at .85 is because I didn't want to buy new coils.
  14. Sep 14, 2013 at 5:26 AM
    smartmonkey
    smartmonkey Member
    Bangor Maine
    2011 Tacoma SR5
    I switched to 265/75/16s and i have 5100s on the front set at 1.75. I had a chevy dealer do the alignment after.. I dont trust my dealer any more..get a print out with before and after. A re-alignment is a must. The only vibe is from that damn needle bearing issue ,but Im doing that myself here in a few weeks. Also i keep my tires at 32 psi religiously..A chalk test may be in order depending on the tire I run michelin LTX MS2s /P rated..There are so many variables involved with lifting that i m leaving it at the increase I get from the 5100 and the rear spring TSB upgrade. Blue Skies
  15. Sep 14, 2013 at 10:21 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    My major vibration was just my drive line. So I flipped it and made a huge difference.
  16. Sep 14, 2013 at 8:06 PM
    Ninjayota
    South Texas
    Reading about all these vibes, noises, and after lift problems makes me wonder if I should just stay stock.
  17. Sep 15, 2013 at 8:46 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    No no. I only had one vibration. Drive shaft. Just flip it around. Other people have other problems. I have a 3 inch lift on mine. All I can tell you is that it was worth the money!
