Single cat exhaust question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by millerza, Mar 15, 2023.
  1. Mar 15, 2023 at 1:02 AM
    millerza
    millerza [OP] Member
    Zach
    Choctaw, Oklahoma
    2002 4X4 Regular Cab
    Stock
    Will a single cat exhaust(pre 99) bolt up to a dual cat(2002) truck? Given that you remove the second cat. With no cutting/welding.
    2002 3RZ
  2. Mar 15, 2023 at 1:52 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    No, I think the exhaust header is a different length, and so is the cat-back
  3. Mar 15, 2023 at 1:55 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    FWIW I replaced my entire two cat exhaust line from the header to the tailpipe with a pre-99 one cat configuration exhaust line. It all bolted up that way. (I should note I have a single “test pipe” where the cat should be and the LCE header which is designed to bolt up to the one cat exhaust line)
  4. Mar 15, 2023 at 2:27 AM
    millerza
    Zach
    Choctaw, Oklahoma
    Stock
    Well hell. Didn’t want to hear that. Guess cutting and welding are in my future.
  5. Mar 15, 2023 at 6:05 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Must be great not having any Emission inspection.
    Jakuku Pahwheenis likes this.
  6. Mar 15, 2023 at 6:06 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    It is great actually :burnrubber:
