Single click noise when backing up and breaking.
Discussion in 'New Members' started by Goldentaco12, Aug 14, 2017.
  1. Aug 14, 2017 at 4:43 PM
    Goldentaco12
    Goldentaco12 [OP] Member
    Rob
    2011 4cyl 4x4
    Billet grill, Brembo brakes, plastic dip wheels, 32" tires
    Having some issues... number one when truck first starts it feels a bit rough like an unnecessary vibration. Second when accelerating it shifts a bit hard. When I break after driving for a bit it, when I come to a complete stop it feels like there is a single click noise? Anyone who can help me out
  2. Aug 14, 2017 at 4:50 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    New plugs and fuel injection done in march, oil change done Sunday, trans flush done marchish, brakes were done last weekend. I don't think it's my brakes done a few break jobs before and when I break or release the break the clicking noise doesn't always seem to happen.
    scottalot likes this.
  3. Aug 14, 2017 at 4:56 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    Yeh it is a pain. Truck runs fine. 154000 Kms. I think the rough idle could be a loose engine mount. But the click I'm concerned. Brakes push and release with ease. Not effort there. It's like when a load/ force like backing down my driveway I get it.
  4. Aug 14, 2017 at 4:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Brake job. Transmission flush.
    Carrier Bearing may be shot also.
  5. Aug 14, 2017 at 4:58 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    It was either upper or lower maf sensor replaced 1.5 years ago. And when that happened truck stalled so imagine same thing will happen when the other goes
  6. Aug 14, 2017 at 4:58 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    Ahh, can I ask you why the carrier bearing, I thought that as well, and I've been told it has a lot of play.
  7. Aug 14, 2017 at 5:01 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    Front end, I also saw a post that maybe shocks or springs are shot what do you guys think
  8. Aug 14, 2017 at 5:10 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Brake slap?
  9. Aug 14, 2017 at 5:12 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    I just looked into the spring/ coil issue. And I rotated the tires when I did the brake job. Noticed excessive scalloping on driver side. Also had scalloping on passenger but not so bad. I'm running the Goodyear duratracs. I was told that it's quite normal with the duratracs but u know think it's a spring.
  10. Aug 14, 2017 at 5:12 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    What's brake slap
  11. Aug 14, 2017 at 5:18 PM
    Goldentaco12
    Rob
    2011 4cyl 4x4
    No lift.
    scottalot[QUOTED] likes this.
  12. Aug 14, 2017 at 5:44 PM
    ecgreen
    Sean
    When you are coming to a stop and you put on the brakes (usually harder) you hear a clunk. Happens in reverse too. The brake pads are known to sometimes slide in the calipers.
    <iframe width="640" height="360" src="https://www.youtube.com/embed/nF3wfjh6chY" frameborder="0" allowfullscreen></iframe>
