Single drive shaft. Ya-Nay?
Discussion in 'Technical Chat' started by 10TRDOFFROAD, Jan 8, 2011.
  1. Jan 8, 2011 at 11:05 AM
    10TRDOFFROAD
    10TRDOFFROAD [OP] Well-Known Member
    Jamf
    Las Vegas
    10 TRDOFFROAD Quad 4x4
    There has been some discussion on this topic. But can someone tell me why you would want one. If there the way to go. Why are the stock drive shafts two pieces. Thanks.
  2. Jan 9, 2011 at 9:55 PM
    A7XT
    A7XT Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    The single piece one is mainly to correct driveshaft vibrations you get from lifting the truck and hence changing the angle of the shaft. The 2 piece is prone to vibrate if the angle is changed too much because the carrier bearing crossmember is weak. The one piece is probably a stronger driveshaft anyway. hope this helps
  3. Mar 30, 2011 at 12:57 PM
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    Are there any failure concerns with the one piece over the two piece?
