Single-piece driveshaft for DCLB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ardrummer292, Jun 20, 2020.
  1. Jun 20, 2020 at 3:13 PM
    ardrummer292
    ardrummer292 [OP] 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    I'm gearing up to install the 3" front/2" rear Dobinsons lift kit sitting in my living room and I'd like to make sure I have all my bases covered. While I have done my due diligence when it comes to research and implementing preventive measures, there are some things that cannot be fixed prior to becoming a problem. Driveline vibrations is one of them.
    I've got an OME carrier bearing drop kit and some 2 degree shims with extended center pins, which I hope will be sufficient to correct my driveline angles and keep me vibe-free. If these don't work, I'll have no choice but to go with the "nuclear option": a single-piece driveshaft.
    Here's the (potential) issue: I don't know if Tom Woods, or anyone, makes a single-piece driveshaft long enough for a DCLB truck such as my 2015 TRD Sport. I know there are a lot of lesser-known companies that will make pretty much anything for any platform, but I'm inclined to believe that an experienced manufacturer like Tom Woods doesn't offer one for a valid reason.
    Anyone have any experience they'd like to share? I'm all ears.
    Jared8907 likes this.
  2. Jun 20, 2020 at 3:37 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I'd measure it up and call Tom Woods and see what they say.
  3. Jun 20, 2020 at 3:43 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    They can't
    It would have to be a really large dia. or it'll be spinning too fast for the length. I haven't had any issues with my stock one
  4. Jun 20, 2020 at 4:00 PM
    ardrummer292
    Austin
    ESVA
    I think I have all my bases covered, so I'm not expecting any issues. I'd rather be ready for the worst case scenario, which is why I'm asking about this option.
    I wonder if they'd be willing to make a custom, larger diameter driveshaft to prevent instability issues. I'm not sure what kind of interference problems I'd run into with a larger diameter tube, though.
  5. Jun 20, 2020 at 4:07 PM
    riot4wyatt
    riot4wyatt Well-Known Member
    Travis
    Port Allegany, Pa
    '14 TRD off road spruce mica
    Bilstein 6112/5100 1.5" icon aal Dometic cfx40 fridge
    Tom woods will build you one. Or Adams driveshaft.
  6. Jun 20, 2020 at 4:25 PM
    ardrummer292
    Austin
    ESVA
    You know for a fact that Tom Woods will build one for a DCLB? That’s not what I’ve read.
  7. Jun 20, 2020 at 4:29 PM
    riot4wyatt
    Travis
    Port Allegany, Pa
    All they require is the bolt flange spacing and shaft length from the ujoint on the back of the transfer case to the ujoint on the 3rd member. They don't care what it's going on.
  8. Jun 20, 2020 at 4:30 PM
    ardrummer292
    Austin
    ESVA
    They do have a maximum length that they’ll build, which is why I’m concerned.
  9. Jun 20, 2020 at 4:30 PM
    riot4wyatt
    Travis
    Port Allegany, Pa
  10. Jun 20, 2020 at 4:33 PM
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    The issue isn’t what it’s going in, the issue is to build a driveshaft that long and it not naturally vibrate because of the length, they’d have to build it a larger diameter and heavier material than is practical and worth it for a Tacoma. That’s why people don’t do it.
  11. Jun 20, 2020 at 4:35 PM
    MattiveAmerican
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    The maximum length is right in the link shared by riot. 72” is the length of a ACLB OR DCSB, your driveshaft is a foot longer than that
    DaveInDenver likes this.
  12. Jun 20, 2020 at 4:41 PM
    riot4wyatt
    Travis
    Port Allegany, Pa
    Very very sorry! Didn't see it was for a dclb. I'm sure if you talk to them, prolly for a little more money, they can bump up the tube diameter or wall thickness to accommodate...
  13. Jun 20, 2020 at 4:44 PM
    ardrummer292
    Austin
    ESVA
    If I contacted them about getting a custom, larger diameter driveshaft built, what issues do you think I might encounter? Interference issues, sluggish acceleration, stuff like that?
  14. Jun 20, 2020 at 4:48 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    I just measured my 2011 4x4 AC. 67.5" straight line. Where did you get the 72" ?
  15. Jun 20, 2020 at 4:52 PM
    ardrummer292
    Austin
    ESVA
    That’s the max length that Tom Woods will build.
  16. Jun 20, 2020 at 4:53 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    that's now what he wrote.
    ".. 72” is the length of a ACLB.."
    fatfurious2 likes this.
  17. Jun 20, 2020 at 4:57 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  18. Jun 20, 2020 at 5:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just cause you go to a one piece is not a guarantee you won’t have any vibes.
  19. Jun 20, 2020 at 5:02 PM
    ardrummer292
    Austin
    ESVA
    I know. It’s the next logical step if a carrier bearing drop and axle shims won’t do the trick.
  20. Jun 20, 2020 at 5:02 PM
    MattiveAmerican
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    I was estimating it based on my spare shaft when it’s laying in the bed of my truck, could be a few inches off
    ardrummer292[OP] likes this.
