Single Piece Driveshaft = Vibes....BE GONE!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 16, 2017.
  1. Mar 22, 2018 at 4:12 PM
    #381
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    06 TRD Off-Road
    I have the 4" one piece from Tom Woods. I did have to take out the crossmember that held the carrier bushing. As long as you make a clean cut, it can be welded back in easily. The shaft was $560 shipped, which is a lot better than $800. Tom Woods customer service is awesome as they walked me through the differences between the 3.5 diameter shaft vs the 4. I have no vibes and life is good. Good luck OP, let us know how you make out. :thumbsup:
    wilsolo61 likes this.
  2. Mar 22, 2018 at 7:07 PM
    #382
    TacoJuan
    TacoJuan Well-Known Member
    Hanover, PA
    2015 Black Tacoma TRD OR
    Ok so I’m about to pull the trigger on a tw one piece and I’ve been reading through this thread, I just want to make sure I’ve got some things clear... my truck is a 2015 dcsb 4x4. I put on bilsteins all around with ome coils upfront and aal in the rear totaling a 3” lift... I put 3* shims in the rear, the carrier bearing drop at the cb and it eliminated all vibes except the take off vibes up to 20 mph. I will not be re gearing and currently have 32” tires on it... largest I’ll go is 33”. If I read correctly, the 3.5” shaft should work perfectly for me correct? Or should I still go with 4”? Also, in an earlier post, I read the calculated top safe speed with a one piece on 32” tires is just over 75 mph... occasionally I’ll do 80, has anyone had any issues going over 75?
  3. Mar 22, 2018 at 7:19 PM
    #383
    TacoJuan
    Hanover, PA
    Did you have to cut out your cb support bracket with the 3.5?
  4. Mar 22, 2018 at 8:17 PM
    #384
    EDDO
    EDDO                     
    Eric
    San Jose, CA
    13 DC TRD OR MG
        CBI Moab 2.0 front bumper CBI Trail Rider 2.0 rear bumper B.A.M.F. sliders All-Pro IFS, transmission and transfer case skids Exhaust crossover relocate Warn M-8000s winch NorthStar AGM 27F battery, BamaToy1997 Stage 1 Wiring Icon 2.5 front and rear Camburg balljoint UCAs Welded stock alignment tabs Dakar Leaf Springs and 14" x 700 lb. coils Wheeler's SuperBumps (front) Icon Hydro Bumps with U-bolt flip Relentless Fab tailgate plate Total Chaos Bed Stiffeners 265/75R16 BFG T/A KO2 on black TRD faux beadlocks PTR18-35090 Custom Double Cardan Driveshaft from South Bay Driveline 2.5" dia .134" wall front, 3.0" dia .125" wall rear. Spicer 1310 joints, Spicer CB
    Depends. What did Tom Woods give you for a maximum safe RPM specification on the shaft you are buying? How does that compare to the maximum shaft speed you calculated based on your setup and uses? Personally, I didn't want to purchase and install a driveshaft that my truck was capable of blowing up.
  5. Mar 22, 2018 at 8:25 PM
    #385
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    It clears it without cutting fine, but I haven't tried articulating the suspension to see how close I can get it. I haven't done any wheeling with it since the install, but I'll check it out before I do.
    TacoJuan likes this.
  6. Mar 22, 2018 at 8:50 PM
    #386
    Spintly
    Greg
    06 TRD Off-Road
    If you never plan on running anything bigger than 33s, then go with the 3.5. I am on 285s with an icon lift at 2.5 inches in the front and 1.5 in the rear with no shims. TW told me to try it without shims and see if I have vibes. I didn't , so I have no shims in the rear. I have had my truck up to 104 with no issues, and constant 80 mph on a trip to Michigan and back with no issues as well. For me it was worth the investment, but for others, it may not be.
  7. Mar 22, 2018 at 9:23 PM
    #387
    TacoJuan
    Hanover, PA
    Awesome. Thanks
    Spintly likes this.
  8. Apr 20, 2018 at 10:04 PM
    #388
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
  9. Jun 13, 2018 at 9:38 AM
    #389
    bren5279
    bren5279 Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox 12" travel 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.10 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R XD Monster 17x9 -12 Rims 35x12.5 Baja Mud Grappler Tires Baja Front Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    Bump to a fantastic mod for lifted large wheeled tacos, Its one of those things you don't know how much better it makes things until you try.
    Just did this on my '12 4.0 4wd taco that's lifted about 5 inches and on 37's; drastically reduced driveline vibrations and start of vibes. This should be a mandatory mod for all lifted tacos!!
