Single pop/clunk from front suspension?!
Discussion in 'Technical Chat' started by Stig, Aug 9, 2016.
  1. Aug 9, 2016 at 7:59 PM
    Stig
    Stig [OP] Resident smartass
    Brandon
    Ta no mo
    I posted this a few times and it just gets lost in the BS thread. Hoping someone may have a good guess or solution. And hopefully it'll help someone else once I figure out the problem.
    Truck setup:
    OME 885/90021's
    trim packer on drivers side
    No other aftermarket goodies
    Sway bar was removed to isolate noise
    Alignment is within spec with stock UCAs
    27k miles (Lifted for 15k I'd guess)
    I have a single click/clunk/pop that is very obvious and audible. I dont recall if I can feel it through the pedal or steering wheel, but if I can, it is very slight. It is on the drivers front corner that only happens when off-roading and I hit a rock/bump. Doesnt usually happen on washboard type bumps, doesnt happen at all on the paved road even when hitting potholes. Its more of a slow rocky terrain when it'll randomly do it. I have not been able to reproduce it or I would try to get under there while it was making the sound. Since it first started happening, the shocks have been swapped and it remains the same, sway bar removed and its the same, all bolts are tight, checked multiple times. It has had multiple alignments and tire rotations.
    Turning does not matter, has happened when driving straight and turning from speeds of 0.1 to 15mph, in drive and reverse and it has been aligned since the noise started. Has happened in 2 and 4wd.
    I just took off the wheel. pried around between the knuckle and control arms with no signs of any issue. Twisted the tie rod end and it feels smooth.
    I can grab the tire with the truck on the ground and try to shake it all I want with no noise. I am thinking it could be upper ball joint, lower ball joint or tie rod end since there is nothing else that I would think makes the noise. It sounds like a clunk a sway bar would make... but its not on the truck anymore. Any good ways to test if I cant feel anything by wiggling the crap out of it?
    It seems like it happens when the tire is pushed forward or backward since up and down on the street wont reproduce it. Still not sure why potholes wont make it do it.
  2. Aug 9, 2016 at 9:27 PM
    zkdawg
    zkdawg Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
    I had a similar thing with my truck, I couldn't find answers and no one could help.
    One day I had the grill out and was messing around when I found the front body mount slightly loose and the metal part of the bushing was rusty and sticking to the bolt.
    Check there and if so takt the thing of and grease the bolt and bushing.
  3. Aug 9, 2016 at 9:30 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    Do you have the diff drop?
  4. Aug 9, 2016 at 9:30 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I have a clunk from my drivers side front setup when fully compressed going over dips at +10mph. Best answer I've gotten is 'clunking just happens with a lift setup'. I have 5100s set to 0 and OME 881s. Other than the occasional clunk they perform great.
  5. Aug 9, 2016 at 9:36 PM
    Stig
    Brandon
    Ta no mo
    I'll look for it, thanks
  6. Aug 9, 2016 at 9:39 PM
    Stig
    Brandon
    Ta no mo
    Negative
    Meant to put it in the op, but it's not a fully compressed /extended issue. It has happened as soon as it starts to go up or down or slightly after.
  7. Aug 10, 2016 at 8:00 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Wild-ass-guess, but maybe you dropped a steel tool or bolt into a nook/cranny in the driver-side front, and it rattles sometimes.
  8. Aug 10, 2016 at 8:07 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Torque your cam bolts n nuts on the lower control arms to 100ft#'s. I guarantee the person who did the alignment didn't tighten them enough. If you still have the factory front skid, you will need to move it out the way to torque the front two.
    pudge151 likes this.
  9. Aug 10, 2016 at 8:11 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Out of curiosity does the noise ever occur if you are backing up and then moving forward, or changing direction of travel?
  10. Aug 10, 2016 at 8:55 AM
    Stig
    Brandon
    Ta no mo
    Haha nope
    I was able to torque the rear one, it was slightly under torqued. I didn't remove the skid plate to get the front one... Guess I'll try when i get a chance.
    Not the brake noise, it does that sometimes. I mostly fixed that by packing dirt and crap in there.
  11. Aug 12, 2016 at 9:38 PM
    Stig
    Brandon
    Ta no mo
    Checked the front body mounts behind the bumper... tight as can be.
  12. Aug 13, 2016 at 9:14 AM
    Stig
    Brandon
    Ta no mo
    Going to be reinstalling the sway bar today, so i can :burnrubber:again. I'm going to take the skid plate off to get to the front cam bolts to torque them properly.
    Went out on a trail last night to find meteors and I maybe heard the noise twice, and those times i really wasn't positive it was the noise.
    So, :fingerscrossed: that it was the LCA cam bolts being a few lb/ft low.
  13. Aug 13, 2016 at 9:21 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I had that issue with my lca cam bolts
  14. Aug 13, 2016 at 9:24 AM
    Stig
    Brandon
    Ta no mo
    I find it stupid, yet expected that Toyota would not notch the skid to make it easier to access the front bolts...
    They should know that the chances are unlikely that some guy at a tire place is going to give a crap enough to go through all the work to torque the front ones properly. But had i known that it was the case that they are basically inaccessible, i would've checked those first.
  15. Aug 14, 2016 at 5:47 PM
    Stig
    Brandon
    Ta no mo
    I dropped the skid to torque the LCA bolts to 100ft/lbs. All four needed extra tightening to get them there, the drivers side more than the passenger side. Sway bar is back on, and the leak I found last time I did the one LCA bolt appears to be growing, and coming from the rear main with 27k on the truck. Sooooo... going to the dealer who's done all the service up to this point and we're gonna figure that one out! The last tech had an issue figuring out how to drop the spare tire, and how to do the service report, so... I dont want to jump to any conclusions, but...
  16. Aug 21, 2016 at 9:00 PM
    Stig
    Brandon
    Ta no mo
    Took it offroad today, not a peep. So it was apparently the LCA bolts. I'll have to remember to specify that they torque them down correctly next time I go in for an alignment.
    pudge151 and samiam like this.
