Single Pop or Clunk when Coming to Full Stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drunknsloth, Apr 11, 2013.
  1. Apr 11, 2013 at 11:22 AM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    2008 Access Cab Toyota Tacoma SR5 4X4
    So I'm not sure if I just didn't notice it before or if it just started recently. I haven't done any hard off roading recently except just a dirt trail that would basically be the equivalent of a bunch of speed bumps and I took it way slow.
    I'm getting a single kind of a mix between a "pop" and a "clunk" sound that is coming from what sounds like the center front when I come to a full stop in normal driving. Sometimes there is a faint pop when I am braking maybe around 15 or 20 MPH. But there definitely is one when I come to a full stop. If I coast uphill and start rolling back and brake there is a pop/clunk there too. But if I crawl to a stop with barely any brake pressure I don't hear anything.
    This only happens when I have been going forward. I tried it a few times just putting my truck in first and gassed then braked and I would get a pop/clunk. If I was in reverse and gassed then braked it wouldn't do it.
    This is blowing my mind. I don't know why it does it only when going forward or rolling backwards down hill but not when reversing. Then the occasional faint pop when braking around 20 MPH...
    I've tried searching this and most of what I found was with turning. I had a pop when I was turning at a certain angle going forward and if I put it in reverse right after the pop it would pop again. I just tightened all my LCA camber bolts so hopefully that fixes the problem. I have a Billy + OME 885 lift on the front and everything else is stock. The sway bar does not seem to come close to the coils. Anyone have any insight on this too if the tightening doesn't fix the problem?
    :frusty:
  2. Apr 11, 2013 at 12:34 PM
    Slikk
    Slikk Well-Known Member
    Kevin
    Nashville, TN
    2013 4X4 Off Road
    Watching... i have the same thing but it always from the rear
  3. Apr 11, 2013 at 12:40 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Is this the same as the brake clunk?
    Otherwise I would check your shock bolts and make sure they didn't come loose. Although that would make noise over bumps too.
  4. Apr 11, 2013 at 12:42 PM
    BDJ
    BDJ Well-Known Member
    Brandon
    West Monroe
    2012 TRD OR 4x4 DBL Cab MGM
    Slikk, It's Axle wrap, very common on these trucks.
  5. Apr 11, 2013 at 1:13 PM
    Drunknsloth
    Retribution
    South West
    If it's the rear I almost guarantee it's axle wrap for you.
    I'm not sure. If it was the brake I would assume that it would happen in reverse too, but it doesn't. I'm going to take off my wheels and check my brakes when I have time (hopefully this weekend). I don't hear anything going over bumps.
    If it is the brakes changing out the pads and rotors should fix the problem right?
  6. Apr 11, 2013 at 1:17 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I saw a video, still looking for it, but they said that different brand pads made it stop.
  7. Apr 11, 2013 at 1:19 PM
    Drunknsloth
    Retribution
    South West
    Cool, thanks man :) I'll try looking too.
    But do you think going forwards and backwards would make a difference?
  8. Apr 11, 2013 at 1:30 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Here it is! You can click the arrow beside the Screen name and go to the thread that it was posted in.
    It's likely that since it just started that it isn't doing in reverse yet.
    Sometimes I'll get a noise like this pulling up to a stop light but it's not that often. Even less often I might hear it when backing out of a spot.
  9. Apr 11, 2013 at 2:25 PM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    Mine does that and its a 2012, I figured it was the pads jerkin, some just do that.
    localonthe8s likes this.
  10. Apr 11, 2013 at 2:41 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I agree it's most likely axle wrap. Also make sure the u-bolts are snugged down really tight.
  11. Apr 11, 2013 at 3:32 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Theres no leafs up front.
  12. Apr 11, 2013 at 4:19 PM
    tundrataco
    tundrataco Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    had the same noise, turned out to be rear u bolts not torqued down correctly on one side!
  13. Apr 11, 2013 at 4:37 PM
    08TacoTrD
    08 TRD Offroad
    I drive backwards....:D
  14. Apr 11, 2013 at 4:47 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Sweet skills
  15. Apr 11, 2013 at 7:57 PM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    Same problem here. You start to here things that you never heard before and don't know where it's coming from. You ask yourself, is that normal? this is what I do, crank up the music and keep on trucking.
  16. Apr 12, 2013 at 1:40 PM
    Drunknsloth
    Retribution
    South West
    Okay so it doesn't sound quite like the video and the sound when I come to a full stop and disappeared for now. I still want to check the brakes when I have the time.
    The other problem I stated about the pop while turning is getting louder. It's kind of a loud popping snapping sound that I can slightly feel through the floor board. It's always when I have my wheels turned to the left and it will do it when I am going forward or backward. My wheels aren't in full lock but it seems to always do it at the same angle. I've tried lifting it up and turning the wheels around and seeing if anything is in contact but I can't find anything.
    :goingcrazy:
    Edit: I've also tightened my LCA camber bolts to 100 lbs/ft but one on the passenger side is seized...
  17. Mar 7, 2019 at 9:54 PM
    LukaszK
    LukaszK Well-Known Member
    Lukasz
    Elmwood Park, NJ
    2020 Tacoma DCSB Cement Grey
    Sorry for bringing back this old thread, but I was curious if you ever found the course of this pop/clunk. Have the identical issue on my Tacoma with 885/5100’s.
    Thanks in advance!
  18. Mar 7, 2019 at 10:05 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Possibly the lower or upper control arm bushings. My truck clunked when coming to a stop, ended up being that. They were worn out.
    If yours are oem from 2005 and you offroad even a little, I’d suspect they are worn out.
    In extreme cases the wheel will shudder back and fourth when stoppig as well.
    If it’s coming from the front for sure, the only other thing I’d check is brake pad clunk.
    LukaszK[QUOTED] likes this.
  19. Mar 7, 2019 at 10:13 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    C
    Check the sway bar and make sure it not hitting the coils
  20. Mar 8, 2019 at 12:31 PM
    Drunknsloth
    Retribution
    South West
    It's been a while, I don't quite remember when the noise went away exactly, but since then I've replaced the LCA bushings, sleeves and bolts since they were seized and the noise hasn't come back.
    LukaszK likes this.
