Siping & Grooving tires **PICS**
Discussion in 'Long Travel Suspension' started by Johnnie, Sep 10, 2012.
  1. Sep 10, 2012 at 2:13 PM
    Johnnie
    Johnnie [OP] Well-Known Member
    I.E. SoCal
    Feds
    I just came across a set Falken Rocky Mountain AT tires. From all the reviews and videos I've seen they are a pretty good tire. However, I have one issue with them.
    If you look at the center tread depth versus the shoulder tread depth you’ll notice that the shoulder tread depth isn’t as deep as the center. Therefore, as the tire starts to wear it will look more like a traditional street tire versus and AT tire. BFG AT’s have full tread depth through out the entire tire which makes sense.
    My solution to this would be a sipe/groove out the shoulder to make it match the center tread depth. If you look at the pictures below you’ll see what I’m talking about. Since LT guys tend to sipe/groove their tires more than non LT guys I figured I would post this in the section so guys with experience can chime in.
    Moreover, instead of buying a tire groover or tire siper I was thinking of using a Dremel with a grinding wheel to achieve this. It sounds like a redneck idea but I think it would work. Any suggestions?
    In this picture you can see the center is deaper than the should tread.
    Another angle of the tread depths
    Worn tires look like street tires
  2. Sep 10, 2012 at 2:17 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Not sure about the siping but I had these tires and only got 10,000 miles out of the 2 that I didnt tear up... I punctured the side wall on one and melted the 2nd... The other 2 were really close to the wear marks at 10K...
  3. Sep 10, 2012 at 2:22 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Tire manufacturers spend a lot of money designing their tire to do a certain thing. I think it's best to find the tire that does the thing you want it to do. Attacking a tire with a dremel does not sound like a great idea to me, and is possibly unsafe.
  4. Sep 10, 2012 at 2:24 PM
    Johnnie
    I.E. SoCal
    Feds
    Damn 10K? They have a 50k warranty. How did you melt one? Unfortunately they haven't been around long enough for long term testing.
  5. Sep 10, 2012 at 2:26 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    these tires sound like garbage
  6. Sep 10, 2012 at 2:33 PM
    Johnnie
    I.E. SoCal
    Feds
    Have you read or seen any reviews on them? Are you familar with siping or grooving? If not, then your opinion isn't really appreciated.
  7. Sep 10, 2012 at 2:46 PM
    ruler
    Well I actually did some research and looked in to these when I was considering some AT's but a majority of reviews I read said that these tires wear fast and don't last very long. And I dont think siping even matters when these tires wear out faster then a TJ prostitute..
    And as far as the siping goes, yeah they work great when there's some tread left but after two rotations these things look like they belong on a rice rocket..
    Not trynna shit on your parade so if you dont believe me I guess we can let the reviews speak for themself..
    http://www.discounttire.com/storeRe...qs.pc=18287&rbqs.ar=70&rbqs.rd=17&rbqs.cs=265
    " A very stiff tire causing my truck to bounce with a slight vibration. The tire I had on before ran very smooth. I regret buying the tires. "
    "idk how the front tires wore so fast."
    " Tire Cons the front almost need replaced?????"
    "Constantly had to correct steering, tires wandered all over the road. Took the tires back after about 500 miles."
    "I think this would be an awesome tire if the sidewall was stronger. I am being carefull on these tires and will be utilizing the 30 day satisfaction garauntee that Discount Tire provides. Go with Discount Tire, but if you have a heavy truck, I would suggest another tire"
    "I have not used the tires under winter conditions yet. I am very disappointed in the ride that I have received so far when no load is on the truck, no weight might be the contributing factor but will say they have better traction in the few wet conditions that I have experienced so far"
    "I have had them rotated twice and they still seem to wear quickly."
    "I even tried to return the tires a couple days later cause they make the jeep feel like the steering is loose, it tracks on grooves in the road and on slopes. I would not recommend these to anyone"
    "Between 40-50 mph, the car has a vibration to it"
    sorry but so far these tires sound like they are POS !
  8. Sep 10, 2012 at 2:58 PM
    Johnnie
    I.E. SoCal
    Feds
    IDK how the fuck this turned into a tire review. I've read all the reviews and you posted 9 bad reviews over all the other good reviews. I'm not debating they may not be the best tire because that is something I'll have to see for myself. If they wear out within 20k miles then I'll agree they are not a great tire. Do your Toyo's have a 100% positive reviews? I doubt it. I've owned Toyo MT's as well and I loved them. They are super stiff but extremely durable. Unfortunately they didn't last as long as advertised either but they did get more than 10k.
  9. Sep 10, 2012 at 3:05 PM
    ruler
    yeah not trying to start a pissing contest, honestly I loved the Toyo's the have lasted longer then any other tire I have owned but they are super heavy and they don't do so well in the snow. (siping sucks)
    With that said my new pair of tires will probably some AT's, i was looking at these cause of the price but reviews weren't so promising.. Think I will go with either BFG AT's or Hankook. Don't get Nitto Terra Crapplers either they wear almost as fast as the Falkens
  10. Sep 10, 2012 at 3:49 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    In my opinion, don't waste your time siping them. You sipe tires so they perform better in the wet and snow. Tires that worn are going to suck in foul weather, just slow down, wear your last few thousand miles out of them and toss 'em. Also, don't use a dremel, use a knife if you really feel the need. The high speed dremel will just melt the rubber and it's not strong enough to cut at slow speeds. A rotary tool would be a good option but it needs to be a slow speed tool.
  11. Sep 10, 2012 at 3:52 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    I wouldn't use a dremel since there are several things that could go wrong. (Slipping and accidently grooving the sidewall for one!! :eek:) Also, I think it would make rougher cuts in the rubber (rather than a conventional grooving/siping tool) that could leave the possibility for future deterioration from the stress put on the rubbber.
    I would definately groove and maybe sipe (with the proper tools) those falkens since they do have one of the most retarded wear bars I've ever seen on an all-terrain tire. :laugh:
    PS I work for Discount Tire, and imho those are the worst quality all-terrain tires we carry. Take it fwiw...:eek:
  12. Sep 10, 2012 at 4:05 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    What he said.
    DISCOUNT TIRE EMPLOYEES FTW!
    :cool:
    Using a dremel to sipe a tire isn't the best idea. But from what I read, it looks like you know that. :p
    if anything, use a heated knife. But be careful not to cut too deep into the tread. :eek:
  13. Sep 10, 2012 at 4:19 PM
    Davidd
    Davidd Well-Known Member
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    If you are looking for aesthetics then get a tire that has the look you want. You will waste time and potentially ruin the tire if not done right.
  14. Sep 10, 2012 at 8:21 PM
    Johnnie
    I.E. SoCal
    Feds
    It didn't cross my mind that I can melt the rubber with a Dremel. Maybe I'll just use an angle grinder. [​IMG]
    Why do you think they're the worst AT tire you guys carry? I know they don't have the big name like BFG, GY, General, etc. but from everything I've read and seen they seem to be a pretty good tire. My only concern is long term wear and tear.
  15. Sep 10, 2012 at 8:30 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    I'm in the same boat as Silas over there. It's one of the worst AT tire's we have IMHO. The lack of full depth siping for one thing. From working at discount in Texas, I've seen quite a few different AT tires. If you look at almost all the other AT tires, even when they wear down, they still are able to get traction because of the siping and tread pattern. With those Rocky Mountains, once they get past about 8/32's you get 5 long blocks with no depth to them.
    Another thing, rubber compound. There's a reason Michelin and BFG and Goodyear are high up there. The rubber compound they have come up with is better than Falken's. Not saying all falken's are bad. But for the most part, the other's are better.
    And just letting you know, a cut off wheel would be your best bet :D :crapstorm:
  16. Sep 10, 2012 at 9:07 PM
    Johnnie
    I.E. SoCal
    Feds
    Which is why I suggested siping or grooving.
    In this picture we can see the end result. Regardless, we'll see how I do with them.
  17. Sep 10, 2012 at 9:17 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Like Silas said, if you're going to get close to the shoulder with that thing you'll be using, be very very VERY careful you don't damage the shoulder or sidewall of the tire.
    Post up pics when you've finished! :cool:
  18. Sep 10, 2012 at 11:41 PM
    YotaYota
    YotaYota Well-Known Member
    I personaly have experience with these tires... AND COULDNT BE HAPPPIER!!
    1st. I got 285/75/16 for $160.00 a tire where as BFG km 2 285/75/16 were closer to $285.00..
    2nd.. Great on road/high way driving, given i dont ever go over 80 mph
    3rd.. Aggresive enough for most offroading. I've done everything from 10" of mud for 2 miles to 20"s of snow to dry trail riding with small and large rocks
    4th... 50k mile warranty
    6th.... as of right now with roughly 9000 miles on them they still look brand new and very little tread is gone, i rotate mine every 6000 miles
  19. Sep 10, 2012 at 11:44 PM
    YotaYota
    And once they get worn down, like that pic above, ill either sell them or get them sipped... either way i see getting atleat another 20,000 miles before i get to that point
  20. Sep 11, 2012 at 7:43 AM
    Johnnie
    I.E. SoCal
    Feds
    Good to hear. I also have the 285/16's.
    http://www.youtube.com/watch?v=3TEuvYwZxUs
    This is the Falken Rocky Mountain/Wild Peak tire that was used by Andrew Hoit, Falken VP during King of the Hammers this year. Obviously it's grooved which is necessary for that terrain.
    A different Wildpeak used by the winner of the Every Man Challenge at King of the Hammers. These are DOT approved tires.
