Siren sound when pressing the gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, Oct 8, 2011.
  1. Oct 8, 2011 at 9:56 AM
    saugus
    saugus [OP] Well-Known Member
    Just realized that there is a slight siren resonating sound that I get when pressing the gas. I noticed it at freeway speeds (55+). It's kind of like a radio interference siren sound. I never really noticed it before because I usually have the radio on, but it is a little annoying. Is this normal? I am thinking maybe throttle body noise?
  2. Oct 8, 2011 at 10:14 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Do you have any aftermarket stereo equipment?
  3. Oct 8, 2011 at 10:16 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    It could be alternator whine if you have aftermarket radio. Does it sound like a turbo or a super charger whine?
  4. Oct 8, 2011 at 10:19 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    OR if you do have a aftermarket stereo it could be not grounded correctly
  5. Oct 8, 2011 at 10:24 AM
    saugus
    Yes but the noise does not appear to be coming from the speakers. I am going to clean the tb and replace the air filter later. I will see if the noise remains.
  6. Oct 8, 2011 at 10:24 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    could it be the windshield seals buzzing? there is a TSB on it.
    Mine does it occasionally.
    When I first heard mine I thought it may be a radio issue, but.... it wasn't:eek:
    If not, maybe aftermarket stereo is causing it?
  7. Oct 8, 2011 at 1:21 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    is there a cop in the rearview? :)
    check your stereo grounds.
  8. Oct 8, 2011 at 1:51 PM
    saugus
    Update:
    I drove around town to check it out again and could not duplicate it.:confused: I thought I must have been ultra sensitive the other day. Then I decided to drive fast on the way back and put it in 5th gear. As soon as I hit 62 mph, the noise started up again and continued as I increased speed. It is definitely too annoying of a whine to ignore. Almost certain it is not coming from the speaker (stuck my ear up to the speaker and there was no difference). It is a howling wind siren noise like I remember coming from my old Ford truck carburetor.
    I'm going to pull the air box, clean the maf and tb, replace the air filter and pull the secondary filter. I'll report back later to see if it fixes the issue.
  9. Oct 8, 2011 at 7:44 PM
    G.T.
    G.T.
    CONUS
  10. Oct 9, 2011 at 5:36 PM
    saugus
    Update:
    I did all the things in my last post (replace filter, remove secondary, clean tb and maf) and now the problem appears to be gone for the most part. There still appears to be a wierd sound but it isn't nearly as bad and almost sounds like it may be the tires. I think the filthy throttle body may be to blame. I feel a little better throttle response from changing the air filter and removing the secondary. The added bonus is that the idle vibrations seem to have gone away. I'll call it success.:cool:
