Sirius and bluetooth help
Discussion in 'Audio & Video' started by semirgdj, Jul 15, 2009.
  1. Jul 15, 2009 at 4:45 PM
    semirgdj
    semirgdj [OP] Active Member
    LA
    09 4x4 Access
    aFe prodry air filter removed secondary air filter center storage lock secured tailgate mod 5300 poplock extra d-rings in bed illuminated 4x4 switch footlights on anytime leather armrests disabled no seat belt warning beeps 20% tint nerf bars Kenwood Nav head unit
    Hi I just bought a 2009 Tacoma (not even 24 hours ago)
    it came with the following factory stereo
    from the toyota website:
    EV) AM/FM 6-disc in-dash CD changer, MP3/WMA playback capability, auxiliary audio jack, satellite radio capability[6], seven speakers including two ceiling-mounted speakers and subwoofer, satellite radio receiver prewire and antenna
    My stereo is sat ready and I do have a sat antenna on the roof, but when I push the sat button on the unit....nothing.
    My question is, what do I need to install for the Satellite radio and what do I need to install for bluetooth.
    Can I install what I need my self? (I am pretty good with that stuff)Or should I have the dealer do it since its new?
    Any info about what I need to buy and instructions would be great.
    THANKS
  2. Jul 16, 2009 at 6:17 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I am betting you need to get the tuner for the SAT radio and quite possible the same for the bluetooth to work. Hopefully its not via Stealership.
  3. Jul 19, 2009 at 10:31 PM
    semirgdj
    LA
    09 4x4 Access
    I ended up putting a complete new unit in. It was cheaper than adding everything on that I needed. AND now I have nav and DVD and EVERYTHING works through me radio
  4. Aug 20, 2009 at 7:22 PM
    TOOLguy420
    TOOLguy420 Spiral out...
    Mark
    Holden, Maine
    '11 SR5 4X4 AC Mag Gray
    Eclipse AVN6620 w/iPod Bluetooth & Sirius, RF SP-64, JL ZR525csi, Q-logic kicks, JL HD600/4, JL HD750/1, JL 12W6v2, ToyTec 3" Ultimate, LR UCAs, SS Brake Lines, BEL Vector, Wet Okole
    What unit did you get, if you don't mind me asking. I just got an Eclipse AVN6620 that I'm about to install...
  5. Aug 20, 2009 at 8:28 PM
    semirgdj
    LA
    09 4x4 Access
    I put in the Kenwood DNX6400 I also have the matching install kit/ dash that matches the factor "metal" dash look.
  6. Aug 20, 2009 at 8:33 PM
    TOOLguy420
    Mark
    Holden, Maine
    Nice! Did you get the Scoshe or Metra kit? Smooth or dimpled?
  7. Aug 20, 2009 at 8:57 PM
    KAPendley
    KAPendley Best Hack I Know
    Andy
    Hickory, NC
    96 2WD V6 Extended Cab
    Shaved, Lowered,Airbrushed (some)
    Im not familiar with the stock setup. But from what your wrote, if its at sat prewire, you will need the sat tuner for it to operate. Perhaps the BT is in that unit as well? Im not sure, but you may have to consult the manual. It should at least tell you how to pair your phone with the HU, then that would give you an idea of whether or not the BT operates or not. GOOD LUCK!!
  8. Aug 20, 2009 at 11:33 PM
    semirgdj
    LA
    09 4x4 Access
    I got the Metra kit, dimpled...it fits and looks GREAT! Most people think its factory when the see it.
