Sirius Antenna location
Discussion in 'Audio & Video' started by Pilvr83, Apr 26, 2017.
  1. Apr 26, 2017 at 7:46 AM
    Pilvr83
    Pilvr83 [OP] Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    I "inherited" a Sirius radio and Pioneer 4200 NEX after upgrading my wife's car. When I initially installed the Sirius radio antenna in her vehicle (2014 Honda CRV) I could not fish the wire through the firewall so I cut the wire in half then soldered the wire back together. It worked great.
    Note: I left the modified antenna with CRV; purchased new.
    My truck is a 2007 double cab.
    I did search the forum but could not find any information on the best mounting spots.
    Where is the best place to route the antenna wire to the headunit?
    Thanks,
    Greg
    TXpro4X4 likes this.
  2. Apr 28, 2017 at 9:14 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I just set mine above the passengers seat on the roof. Routed it down along the window and inside the door, behind the glove box to the radio. I was worried the wire would eventual break because of opening and closing the passengers door but it's been fine for over 2 years now. Some people have had luck keeping it inside the cab, center dash area.
  3. Apr 28, 2017 at 7:46 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
  4. Apr 28, 2017 at 7:47 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Pics of antenna plz
  5. Apr 28, 2017 at 7:51 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    When I had the stock Sirius puck I just ran it up on top of the dash from the radio module I had in my glovebox. Reception sort of sucked with clouds out or whenever I guess I was driving opposite from the satellite (if that's how that works).
    After that I had it up on the roof for a while using an aftermarket antenna. There is a small maybe 1" grommet on the passenger side of the engine bay you can run the wire into the cab through. There's some carpet behind it you'd need to snip a hole in then fish it on in with a straightened coat hanger or something.
    Antenna is now mounted in the bed. Ran the cable from glovebox down to the plastic door silk trim pieces and out through the rear of the cab via a grommet behind the storage cubby.
    Just a couple options based on what I've done.
    Roof mounting was the best for reception. Never dropped out. Dropped out often on dash. Drops out rarely mounted on the bed rail.
  6. Apr 30, 2017 at 1:30 PM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    Thank you. I ran it over drivers side roof down windshield weather stripping to engine bay. Could not figure how to get to cab. Saw the area on passenger side but thought I would not have enough cable. Ran it under truck up through drivers seat grommet.
    In hindsight, should have followed your suggestions. What a cluster I made.
    It is at radio now but not happy with placement; will not move again!
