Sirus radio and bluetooth connection cuts out
Discussion in 'Technical Chat' started by boydb, Aug 14, 2011.
  1. Aug 14, 2011 at 11:13 AM
    boydb
    boydb [OP] New Member
    boyd
    salem, OR
    2010 Tacoma double cab
    Antenna problem I think....
    newbie here- so be kind.
    2010 Tacoma problem with sirus and blue tooth - sirus radio cuts out if a tree is anywhere in sight. People I call via cell phone on the blue tooth in the cab say I am breaking up badly... every other word - whether I'm in the city or on the road in the country....
    my question is: Is ther a replacement antenna I need to install over the OEM antenna??? Or what is the fix ????
  2. Aug 15, 2011 at 9:55 AM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    The bluetooth uses a separate antenna that doesn't relate to the serious radio. Is your tacoma still under warranty? If so I would have them check it out. You might have a bad microphone that is messing up the bluetooth and a bad antenna that is messing up your serious radio :notsure:.
    I have heard that the new amplifier they put in the 2009+ jbl systems has caused a popping sound and as long as you're still under warranty toyota will replace it. You can read more about that -> here
