Sis's SUV dies after starting
Discussion in 'General Automotive' started by theredofshaw, Dec 20, 2013.
  1. Dec 20, 2013 at 9:42 PM
    theredofshaw
    theredofshaw [OP] Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    My sister has run into an issue with her 2002 Mitsubishi Montero. It dies after starting. It starts no problem, it has a new battery and alternator (both less than 6 months old) but it keeps dying after it runs for a few minutes. It also does not show any check engine lights when this happens.
    Ideas?
  2. Dec 20, 2013 at 9:52 PM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    fuel pump and/or fuel filter? could be a number of things but you have to start checking them off one by one unless you bring it to a shop
  3. Dec 20, 2013 at 10:01 PM
    theredofshaw
    she's strapped for cash. roommate left her high and dry on the lease and bills (as in just plain disappeared). fuel filter will be her first shot.
  4. Dec 20, 2013 at 10:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check the IAC valve. I had a 3000GT that had a nasty IAC valve that would decide to turn the car off at idle. Either way, you might want to pull it out, check it and make sure it is very clean. Process of elimination, if you don't have fancy voltage readers and stuff. Is it only when she idles or is it as she drives too?
  5. Dec 20, 2013 at 10:15 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Injectors?
  6. Dec 21, 2013 at 6:14 AM
    theredofshaw
    More info, idling its fine, on accel it dies.
  7. Dec 21, 2013 at 8:09 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    John, I would check the air filter first, then the fuel filter.
  8. Dec 21, 2013 at 8:22 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Air filter/ fuel filter/ fuel pump... Sounds like its starving not enough psi from the fuel pump could cause this
  9. Dec 21, 2013 at 11:03 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Agreed. Check that air filter good too because it's possible (nothing is right?) That the a plastic bag could have gotten sucked in and is clogging up airflow. I've seen it happen before!
