Sits slightly nose up after leveling kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tomsfirsttaco, Jan 6, 2015.
  1. Jan 6, 2015 at 6:43 PM
    Tomsfirsttaco
    Tomsfirsttaco [OP] New Member
    Tom
    Tampa
    08 Reg cab base 2wd
    Lifted leveled,31s
    Don't know if it's just me but my truck isn't seeming level after getting a leveling kit. Had a local place do it on a recommendation but have my doubts based on a few things..... Is this possible and if so, is it common? Do I need to add an add a leaf? Hard to tell but maybe only slightly higher
  2. Jan 6, 2015 at 6:45 PM
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    Get some tape out and run some height measurements on each corner. Oh, and pics
  3. Jan 6, 2015 at 6:46 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    spring perches upside down?
  4. Jan 6, 2015 at 6:47 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    How much lift was the leveling kit? What was the leveling kit?
  5. Jan 6, 2015 at 6:51 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I had the same problem when I put 5100's in the front of my truck. It ended up just a tad higher in the front. Luckily, I already had RideRites in the rear. 2lbs more air in the back, and it was sitting level.
    Just measure the pinch weld at the front of the cab, and then at the back. Then, you'll know for sure.
  6. Jan 6, 2015 at 6:53 PM
    DpS
    DpS Well-Known Member
    David
    Albuquerque
    2015 tacoma sr5 4x4 access cab
    2.5 Fox coilovers shoxs remote reservoir with dsc. total chaos ucr. Rear deaver mini 3 pack aal with 2.5 adjustable fox shoxs.
    I dont know much about leveling kits. But im assuming if its a polyurethane spacer like ive seen on jeeps maybe after it breaks in from the front end weight it'll level out. Or maybe you have a 4cylinder instead of the 6 so your missing some weight. It could be that you dont have the tow package so your missing the 1/2" thick overload spring which would lift the rear a 1/2
  7. Jan 6, 2015 at 6:54 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    He has a base regular cab, so no tow package.
    He definitely has a 4 cylinder.
  8. Jan 6, 2015 at 6:58 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    What kit is it?
