Sittin a little ass low.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jtrevizo16, May 21, 2018.
  1. May 21, 2018 at 4:23 PM
    Jtrevizo16
    Jtrevizo16 [OP] Well-Known Member
    Joel
    2016 Tacoma trd off-road quicksand DCLB
    Stock for now
    My taco is saggin in the back. By a .5 in. I have 885s/5100. Is there .5 block available or would an AAL fix it?
  2. May 21, 2018 at 4:29 PM
    eon_blue
    Azusa, CA
    If it's just an inch or so lower in the back then an AAL should fix it...most give anywhere from .75" to 2" of lift depending on which brand you go with.
    If you want the factory rake back (sit higher in the rear) then look at the 3 leaf AAL packs like what Headstrong sells...those give about 2.5" of lift with the overload left in.
    It's usually ideal to have the back sit slightly higher than the front to account for weight in the bed
  3. May 21, 2018 at 4:31 PM
    Jtrevizo16
    Joel
    Stock for now
    I want to sit level my dude. Cali leanin right now lol
  4. May 21, 2018 at 4:33 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    You can buy a 1” block. I know there’s a lot of hatred for blocks here, but if you like your ride, and just want to get a tiny bit of rake back, a 1” block would be ideal, and cheap.
    CaptainBart45 likes this.
  5. May 21, 2018 at 4:35 PM
    doorsidedown
    doorsidedown Well-Known Member
    get the headstrong off-road progressive aal and remove your overload. Will look nice and ride nicer.
    Jtrevizo16[OP] likes this.
  6. May 21, 2018 at 4:36 PM
    Jtrevizo16
    Joel
    Stock for now
    Roger that thank you. I don’t like the Cali lean. Now that I’m going to throw wheels on I really want it to sit level
  7. May 21, 2018 at 4:36 PM
    bangin4WV
    bangin4WV Well-Known Member
    Rocky
    WV.
    2016 SR5 2.7 MGM ACLB
    33s/sliders
  8. May 21, 2018 at 6:32 PM
    Jtrevizo16
    Joel
    Stock for now
  9. May 21, 2018 at 7:39 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I got the Wheelers 1.5" inch progressive add a leaf with the 5100s. It
    rides just a little better than the TRD Sport, stock.
  10. May 21, 2018 at 7:47 PM
    doorsidedown
    You’ll need two... they’re sold individually.
    I’ve got a brand new pair of these and center pins for them, I never installed them. If you want, I’ll sell them to you for $10 plus shipping. I’m sure they’ll fit in a small flat rate box.
  11. May 21, 2018 at 7:54 PM
    Jtrevizo16
    Joel
    Stock for now
    Would I need longer ubolts?
  12. May 21, 2018 at 7:55 PM
    CaptainBart45
    Bart
    Work in progress...
    Kit comes with U bolts and for both sides .....160 bucks.
  13. May 21, 2018 at 7:56 PM
    doorsidedown
    Most likely.
  14. May 21, 2018 at 7:58 PM
    doorsidedown
    Your best option is still the progressive aal, which as stated above, comes with the ubolts. If you want those 1/2” shims, it’s cheaper, but would give you the 1/2” you’re looking for.
  15. May 21, 2018 at 8:00 PM
    CaptainBart45
    Bart
    Work in progress...
    Oh the stock U bolts should go 1/2" higher no sweat. Sorry to butt in. I just installed the Wheeler's 1.5" progressive aal and thought about using the stock U bolts because the Kit U bolts were really over kill I thought.
    savethewheels likes this.
  16. May 23, 2018 at 1:41 AM
    adrian_tsn
    adrian_tsn Well-Known Member
    Adrian
    Oak Harbor, WA
    17 4x4 DCSB V6
    Bilstein 5100 w/ OME 887 Springs HS AAL w/ Overload TRD Pro Grille w/ Raptor Lights TRD Pro Shift Knob TRD Pro Skid Plate Morimoto HID and Fogs 285/75/16 Nitto Ridge Grapplers Method NV’s Westin Automotive Running Boards
    I was actually about to pull the trigger on this setup hoping it will level the front without touching the rear. I guess I would have to purchase the AAL from headstrong. Which should approximately make the rear higher about 1inch or less.
    Do you have any pictures to show how bad the lean is?
  17. May 23, 2018 at 4:12 AM
    Jtrevizo16
    Joel
    Stock for now
    No I don’t. But I will shoot some over to you today. It’s nose high. It’s noticeable
  18. May 23, 2018 at 5:15 AM
    Jtrevizo16
    Joel
    Stock for now
    Also i took measurements 21.5” in the rear and 22” fronts
    doorsidedown likes this.
  19. May 23, 2018 at 7:42 AM
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    I just installed Toytec 1/2" shims (blocks) in the rear and did NOT need longer U Bolts.
  20. May 23, 2018 at 7:56 AM
    Jtrevizo16
    Joel
    Stock for now
    Nice. Sitting nice and level now?
