Sitting lower in front with suspension lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Critta93, May 30, 2012.
  1. May 30, 2012 at 11:55 AM
    Critta93
    Critta93 [OP] Well-Known Member
    Virginia
    2000 Toyota Tacoma SR5 TRD Offroad V6
    3" coil over suspension lift and 3" body lift on 35's.
    I have a 2001 Tacoma extended cab and i put a toytec 3" suspension lift on it and it sat lower in front. Now, i replaced the spacers up front with bilstein 5100 adjustable shocks and it sits about a 1/4" higher than before (still not enough). I need to know what kind of coil springs to buy to lift my truck up to be level. I need about an 1" or 2" to get back to level. Help?????:confused:
  2. May 30, 2012 at 3:24 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you can't go any taller than 3" up front with stock lower and upper arms... if the rear is sitting higher, the rear lift is too much...
    at 2.5 to 3 inch front lift, you want to do 1.5 to 1.75 inch lift in rear to level out...
    what did you put in the rear?
  3. May 30, 2012 at 3:28 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    LONG FUCKING TRAVEL
  4. May 31, 2012 at 8:30 AM
    Critta93
    Virginia
    I realize that you can't go higher than 3" but can i put aftermarket coil springs to make it sit higher?? i've heard of the ome 881 882 883, not sure what i need but i know they make them. Which do i need?
  5. May 31, 2012 at 8:31 AM
    Critta93
    Virginia
    Oh, and i have a 3" block in the rear that came with the toytec suspension lift i put on
  6. May 31, 2012 at 8:42 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I used a OME 881 spring. That will give you 1.5 inches of lift, I think, maybe 1.75 inches and then I went with the 5100 set at mid clip. If that doesn't level it I suggest using a smaller block in the rear.
  7. May 31, 2012 at 8:46 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    I just looked and you may want a OME880 here is Wheelera site. Give them a call.
  8. May 31, 2012 at 8:52 AM
    Critta93
    Virginia
    Thanks for the help guys!
  9. May 31, 2012 at 8:53 AM
    Critta93
    Virginia
    Thanks guys! That's actually not a bad price on those springs. I'll be giving them a call soon to level out my truck.
  10. May 31, 2012 at 8:59 AM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    I had to do 3" Front/2" Back to level
  11. May 31, 2012 at 9:15 AM
    Critta93
    Virginia
    How do i get my picture to show up on my replies???? I went to control panel and put my picture on my signature but it still doesn't show on a reply?!
