Size bolt that holds bed to frame?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rangerman28, Dec 3, 2011.
  1. Dec 3, 2011 at 7:55 AM
    rangerman28
    rangerman28 [OP] Member
    Scott
    TX
    03 Tacoma
    Does anyone know what the bolt is that holds the bed to the frame rail? I've been searching for afew hours and all I've found is a post from another forum saying its a 17mm but nothing about the what kind of bolt. Just seeing if anyone could help me out.
    Thanks!
  2. Dec 3, 2011 at 7:58 AM
    rcfreak201
    rcfreak201 Well-Known Member
    the title says bed to the frame but in your post you said bed to frame rail, are you talking about the ones on the floor holding the bed down or the scews holding the bed rails on?
  3. Dec 3, 2011 at 8:06 AM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    17mm i think
  4. Dec 3, 2011 at 8:10 AM
    rcfreak201
    Hopefully this is what the OP wants as well but what's the size of the bolt for the bed tithe frame? The star shaped one. I put my tire carrier on and accidentally stripped one..
  5. Dec 3, 2011 at 8:17 AM
    DreDog
    DreDog Well-Known Member
    Andrew
    It's the Torx T55 star. I bought mine at autozone with a with a attachment for the top
  6. Dec 3, 2011 at 8:20 AM
    rcfreak201
    K thanks dre. So the bolt is called a T-55 star? Or is that the name of the socket?
  7. Dec 3, 2011 at 8:21 AM
    DreDog
    Andrew
    It's just called the Torx T55 star. The socket is welded to it. Cause it's such a big size you can't twist it like a regular Allen. I'll post a pic right now
  8. Dec 3, 2011 at 8:23 AM
    rangerman28
    Scott
    TX
    03 Tacoma
    Sorry I got my words mixed up. I'm talking about the bolts that actually hold the ded to the frame of the truck. I've been getting a kind of thuding sound when I go over speed bumps. I checked it out and I can lift the front passenger corner of the bed so I checked underneath and the bolt is missing to attach the bed to the frame.
  9. Dec 3, 2011 at 8:28 AM
    DreDog
    Andrew
    if this is the "bed bolt" your talking about. the T55 star will do it
  10. Dec 3, 2011 at 8:29 AM
    donaldwagner
    donaldwagner -Don-
    Donald
    2013 single cab 4x4
    oh right, 2nd gen, my bad
  11. Dec 3, 2011 at 8:30 AM
    DreDog
    Andrew
    woah 38.5's are HUUUGE on a taco
  12. Dec 3, 2011 at 8:33 AM
    rangerman28
    Scott
    TX
    03 Tacoma
    Actually I have a 2003 so its a 1st gen. I probably should've put that in the original post so my bad.
    Thanks for the pictures but not the bolt I'm talking about. I'll get a picture and post it up of where I'm talking about in just a bit.
  13. Dec 3, 2011 at 8:36 AM
    DreDog
    Andrew
    Thanks for the pictures but not the bolt I'm talking about. I'll get a picture and post it up of where I'm talking about in just a bit.[/QUOTE]
    i was still in bed when i picked up my phone and saw this thread. and i went out side in the freezing cold for your first gen?! :annoyed: haha
  14. Dec 3, 2011 at 9:13 AM
    rangerman28
    Scott
    TX
    03 Tacoma
    Here's the spot I'm talking about.
    The first- I'm pointing the bracket where the bed is supposed to be bolted to.
    2nd- where the bolt is supposed to be.
    3rd- a shot of how the bed can be lifted from the bracket since the bolt is non existent.
    Hope the pictures help
  15. Dec 3, 2011 at 9:14 AM
    rangerman28
    Scott
    TX
    03 Tacoma
    i was still in bed when i picked up my phone and saw this thread. and i went out side in the freezing cold for your first gen?! :annoyed: haha[/QUOTE]
    haha Sorry! But you have to give me the benefit of the doubt that this topic is in the 1st gen tacoma section.... :D
  16. Dec 3, 2011 at 9:16 AM
    DreDog
    Andrew
    haha Sorry! But you have to give me the benefit of the doubt that this topic is in the 1st gen tacoma section.... :D[/QUOTE]
    its koo
  17. Dec 3, 2011 at 11:43 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    When I took off my bodylift I found that the head of the bolt you are looking at is 3/4, I think thats about 17< but I couldn't matchup the threads with any bolts I could find so what I did was retap the thread and use regular bolts 3/4 head, 7/16's shaft and coarse thread. Don't hold me to that 7/16's, my memory is fading, but that is the solution I would recommend. I'm sure the stock bolts are like 20 bucs at the $tealership.
  18. Dec 3, 2011 at 3:02 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    It would be metric.
  19. Dec 4, 2011 at 5:25 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    M12x1.25 and its probably like 30mm long.
  20. Jun 24, 2014 at 1:38 PM
    RileyLAFD
    RileyLAFD Well-Known Member
    Riley
    City of Angels
    '14 DCLB Magnetic Grey
    I guess I've got to start this very soon....
    So I got a T55 for my 2014 Taco… Not the right size… Any one know which is the correct size for the bed bolt?
