Size of N-Fab Step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oday450, Feb 7, 2015.
  1. Feb 7, 2015 at 7:47 AM
    Oday450
    Oday450 [OP] Active Member
    Peoples Republic of Maryland
    '07 Speedway Blue Off Road AC; '14 Silver Sky Sport AC
    What is the long dimension of the N-Fab Nerf step? My wife has had orthopedic surgery and will need to place both feet In the step when climbing into the truck. If not wide enough, I will have to look at other nerfs or running boards. Would prefer the N-Fabs if useable.
  2. Feb 7, 2015 at 8:10 AM
    devkurf
    devkurf Member at Large
    midwest
    I would look at something else in your case. The steps are a little forward on the door, and dont stick out very far from the bar. You can really only get about the ball of your foot on the step itself. Its not really in the right position and dosent stick out far enough to put both feet on when climbing in the front.
    The factory running boards may be better suited to your needs. They dont look too shabby either.
  3. Feb 7, 2015 at 5:32 PM
    Oday450
    Thanks for the feedback. I haven't seen them installed so this helps a lot. Will look elsewhere.
