Size of Tires
Discussion in 'Wheels & Tires' started by jcartee2, Feb 28, 2013.
  1. Feb 28, 2013 at 4:48 PM
    jcartee2
    jcartee2 [OP] New Member
    Alicia
    Georgia
    2013 Tacoma 4x4 Double
    I am going to put a 3" leveling kit on my 2013. What is the biggest size tire that I should go with? Also, what is the best rims?
  2. Feb 28, 2013 at 10:49 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    I would recommend you browse through the forum and see if there's a setup that you like and go from there. Typically, 32" or 33" tires is what most members are running on a 3" lift. Choosing the right set of wheels is very subjective, but I do recommend SCS wheels:D.
  3. Feb 28, 2013 at 10:53 PM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    id go with 33's may require minor trimming. even if they dont rub fenders or pinch welds driving on the road, you have to take into consideration when going off road and having a little bit of flex... otherwise go with 32's. thats what im doing. you can fit a 265/75R16 or 265/70R17 stock but also looks good with a 3"
  4. Mar 1, 2013 at 1:49 PM
    jcartee2
    Alicia
    Georgia
    I'm starting to look around now. Thanks
  5. Mar 1, 2013 at 1:51 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    285/70/17 will fit with minor trimming. 265/70/17 look good with No trimming and better milage. I have a 2 inch lift with 265/70/17 goodyear wranglers and 17" blackrock 909b rims.
