Size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tig3r_Bit, May 19, 2020.
  1. May 19, 2020 at 8:06 PM
    Tig3r_Bit
    Tig3r_Bit [OP] Well-Known Member
    2018 TRD OR 4x4
    I need a hitch pin. What size for a 2018 Tacoma.
  2. May 19, 2020 at 8:09 PM
    Dano461
    Dano461 Well-Known Member
    2019 Off Road Double Cab 6MT
    my guess is any you buy will fit.
  3. May 19, 2020 at 8:40 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Receiver is a chonk so longer than typical one. I cant find a link to mine, but someone else will probably be along to do so.
    Locking pin Is what I am referring to.
  4. May 19, 2020 at 8:55 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Almost any pin will fit, a locking pin is another story. Even the one I had on my 2nd gen was to short for my 3rd gen.
    Lt. Dangle likes this.
  5. May 19, 2020 at 8:57 PM
    Lt. Dangle
    Ohio
    Correct about the locking part. I edited my post for that since I omitted it.
    shane100700[QUOTED] likes this.
  6. May 19, 2020 at 9:03 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I gave up and just decided to take it on and off as needed considering I can’t lock it. I could file or grind about 1/8-1/4 off the lock side but haven’t felt the need or desire to go that far.
  7. May 19, 2020 at 9:10 PM
    Lt. Dangle
    Ohio
    I got mine from Menards, but I couldn't find it there to link it. I feel better about it locking when i'm hooked up and away from my truck.
    Amazon has one that looks just like mine.
    https://www.amazon.com/CZC-AUTO-Tra...coding=UTF8&psc=1&refRID=4YXX1AT4Y3WBDXXZHHSP
    Tig3r_Bit[OP] likes this.
  8. May 19, 2020 at 9:13 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
  9. May 19, 2020 at 9:37 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    I bought a locking pin from Harbor Freight. The one I had from my last full size truck wasn't long enough:confused:. The double wall hitch on the Tacoma requires a longer pin. The new, longer pin was just a hair short as it turns out. Probably the thickness of the powder coat. I turned the stop on the pin side down with a lathe for a perfect fit. It really took nothing. I could have chucked it up in a drill press and hit it with a file it took so little material removal. The pin material was softer than I expected too.
    I have one like the lock pictured above, but it rattles and rattles drive me nuts so I went with a different style. The HF lock is $10.00 and from what I have read is just as strong as any other, which means they all are not too hard to defeat. Many of them seem to be the same pin/lock with different branding and pricing.
    Lt. Dangle and shane100700 like this.
  10. May 20, 2020 at 3:54 AM
    Lt. Dangle
    Ohio
    Mine doesn't seem to rattle, but to be fair I may just not notice it due to the cacophony of other sounds my truck makes.
    I have no doubt the lock is not really secure, I like it more to keep someone from being a jackass and swiping the cotter pin like a regular hitch pin uses.
  11. May 20, 2020 at 4:27 AM
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
  12. May 20, 2020 at 4:45 AM
    HP11
    HP11 Well-Known Member
    NH
    2019 Cement Tacoma TRD Sport
  13. May 20, 2020 at 5:42 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    They should be 5/8'' dia., Pretty much all are standard size.
    Tig3r_Bit[QUOTED][OP] likes this.
  14. May 20, 2020 at 5:50 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i bought one at harbor freight and had to grid off some of the inside bolt 1/8" to get it to lock.
  15. May 20, 2020 at 6:04 AM
    Foster Imposter
    Art
    2018 PRO MT
    Its the length that comes into play on Toyotas. The receiver box is thicker than most requiring a longer pin.
