SKF br930978 Wheel bearing assembly question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Macbugs23, Jan 4, 2025.
  1. Jan 4, 2025 at 2:19 PM
    Macbugs23
    Macbugs23 [OP] Active Member
    Ephrata, PA
    2006 Toyota Tacoma SR5 4x4
    Does the above SKF assembly on rockauto.com come with the seal that gets pressed into the steering knuckle? It says it comes with new seals but they are not pictured like the Beck Arnley one which shows the seal in one of the pics.
  2. Jan 4, 2025 at 2:27 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^It does not include that seal or the O-ring on the bearing shoulder. Order the seal separately, National or Timken P/N 710573. SKF sells the O-ring separately under P/N 30192.
    Also check the condition of the seal on the outer CV joint (the seal that mates up with 710573).
  3. Jan 4, 2025 at 6:03 PM
    TacoTuesday1
    FL
    Generally bearing is just bearing either with or without hub. With hub is probably preferable.
    and not additional separate seals. That I think is one on outer CV (side) and one on knuckle.
    replacement is probably ideal. But people have re used them including myself multiple times as they looked fine.
  4. Jan 4, 2025 at 6:12 PM
    Macbugs23
    Ephrata, PA
    Thanks!
  5. Jan 4, 2025 at 6:37 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Why not buy from @05Taco4x4 ? Hes a vendor here
    dk_crew and 05Taco4x4 like this.
  6. Jan 5, 2025 at 10:14 PM
    FJC MAN
    FJC MAN Active Member
    Bill
    2007 FJ Cruiser
    yotabearingsandhubs.com are very competitively priced.
    Doc Samson likes this.
