skid plate bolt broke off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PINS Runner, Jul 21, 2017.
  1. Jul 21, 2017 at 5:40 PM
    PINS Runner
    PINS Runner [OP] Well-Known Member
    Larry
    Schertz, TX
    2011 DC TRD Off Road 4x4
    OME 885x coils with OME 9000 shocks, OME N182 rear shocks with AAL for TSB, LC UCA, 17x9 Moto Metal 909, 265x70 General Grabber AT2, hard Leer Tonneau cover (in fall & winter) Bestop Supertop (in spring & summer), Andres Devil Horns, WeatherTech FloorLiners (front & back), Air Lift RideControl air bags, ECGS bushing mod, Tom Wood's double cardan driveshaft, Matt123 skid plate, avid light bar, Rampage 22" LED light bar
    Need ideas....I broke off the head of the mid skid bolt. I got an extractor bit. was tying to center punch it so the drill would stay in the middle. The fing welded nut broke away from the inside of the frame. Now just a hole there. And that part of the frame is enclosed. :annoyed:Any ideas? Anyone?
  2. Jul 21, 2017 at 5:48 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Cut it out, weld nut to small cutout piece from frame, weld cutout piece back onto frame. Good luck.
  3. Jul 21, 2017 at 6:53 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    How far from an open part of the frame?
  4. Jul 21, 2017 at 7:26 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I'd probably go for the old "don't worry about it" method
  5. Jul 21, 2017 at 7:46 PM
    Muddinfun
    Muddinfun Well-Known Member
    Can you make something like this and fish it in from a hole somewhere in the frame?
  6. Jul 21, 2017 at 7:51 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Nutsert
  7. Jul 21, 2017 at 8:13 PM
    PINS Runner
    Larry
    Schertz, TX
    About 4 in. I think I could fish a bolt into the hole with safety wire, but there's no way to get a wrench on once its in there.
  8. Jul 21, 2017 at 8:28 PM
    PINS Runner
    Larry
    Schertz, TX
    Damn, just googled nutsert....very cool! May go this direction. Thanks!
    steveo27[QUOTED] likes this.
  9. Jul 21, 2017 at 10:23 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Sorry, I meant from where you could get a wrench in there. Ive taped nylock nuts into wrenches then duct taped the wrench to a piece of steel tubing to fish it in there. Ive also taken a torch to I dont know how many cheap tools to bend them to fit various problem spots.
  10. Jul 21, 2017 at 11:02 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Then have a welder tack weld it.
    Or tack weld a stud in the opening.
  11. Jul 22, 2017 at 8:57 AM
    steveo27
    Pittsburgh
    I had the stock welded nuts on my TRD skidplate do the same thing and replaced them with some rivnuts/nutserts and it worked out perfect
  12. Jul 22, 2017 at 9:55 AM
    PINS Runner
    Larry
    Schertz, TX
    My welded nuts on the TRD skid did it to....I spend too much time at the beach. I just used nut and bolt for it since I could get to both sides. I'll replace those will nutserts too if this works out. Did you use an install tool or a DIY set up I see online to install them?
  13. Jul 22, 2017 at 10:07 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    When I added M8 rivnuts to my bed they were a bitch to do the DIY way. Bought a $20 rivnut tool of Amazon with the dual handles and it was way easier. Smaller rivnuts or the kind that have slits in them so they fan out are easier with the DIY tool. Or maybe I'm just a wimp lol
  14. Jul 22, 2017 at 10:10 AM
    steveo27
    Pittsburgh
    I used the DIY bolt/double nut/washer method. Ive been using this method for all the rivnuts I do. Larger ones like M8 and M10 are a lil harder to do but with some practice, they get easier.
  15. Jul 22, 2017 at 10:17 AM
    PINS Runner
    Larry
    Schertz, TX
    the bolt that broke was an M8-1.25. Would you use a smaller rivnut?
    If I use the M8, assume I will have to drill to make the hole larger.
  16. Jul 22, 2017 at 9:22 PM
    PINS Runner
    Larry
    Schertz, TX
    Thanks for everyone's ideas. I ordered a rivnut kit on Amazon today.
