skid plate removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by malander, Sep 18, 2010.
  1. Sep 18, 2010 at 5:00 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    just tried to paint my skid but cant get it out. all the bolts are out but there must be something im missing, its in there pretty good. any help would be appreciated
  2. Sep 18, 2010 at 5:02 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    is it a factory skid or ????
    it might be just pinched in place
    if you looked it over and all the bolts are out pry it off or get a bigger hammer
  3. Sep 18, 2010 at 5:04 PM
    malander
    max
    01 limited trd 4x4
    stocker ill try it but its solid in there there are 5 bolts correct?
  4. Sep 18, 2010 at 5:06 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    idk on the 1st gen??
    mine had 6 but im 2nd gen.
  5. Sep 18, 2010 at 5:09 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    yes, there should be 2 under transmission and 3 under the radiator, but double check and see if you have 6. the skid is 2 pieces and they clip together. if its wedged in there good it can be a nightmare to pull out. Give it a good yank and bang on it with a rubber mallet.....you cant hurt it by hittin it....it will eventally come out
  6. Sep 18, 2010 at 6:15 PM
    malander
    max
    01 limited trd 4x4
    ahh may have been wedged into the second plate i actually have a missing bolt lol so only 4 but ill take a hammer to it tomorrow
    thanks for the advice
  7. Sep 18, 2010 at 6:24 PM
    davestaco
    David
    Schofield Barracks
    yes the engine skid and tranny skid wedge into eachother.....so that may be it. oh and dont feel bad im missin one to so it very well may be six but i believe its five
  8. Sep 18, 2010 at 6:33 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Five bolts on mine. Three in the front (middle one is longer than the other two) and two in the back. I just took mine off earlier this week to change the oil. Should come right off.
  9. Sep 18, 2010 at 8:01 PM
    malander
    max
    01 limited trd 4x4
    isnt there a hole to change your oil?
  10. Sep 18, 2010 at 8:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    yeah but the filter drips oil all down on it and makes a mess.
  11. Sep 18, 2010 at 8:26 PM
    malander
    max
    01 limited trd 4x4
    if the trucks cool i just put a plastic bag on my hand to untwist the filter straight into the bag works pretty good as long as you get the lip of the bag over the filter
  12. Sep 18, 2010 at 8:29 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    West Coast, Best Coast
    2017 4Runner Smashed Ass Edition
    OME, 285 KO2’s, Fridge, Compressor, Rack, Lights, Switches
    I count 7.
    Three by the radiator, two about even with the hole for the oil drain
    (requires an extension to get to) and two back by the transmission, that adds up to 7.
    Bennett707 likes this.
  13. Sep 18, 2010 at 8:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2, but remember, this is for both the front and rear skids.
  14. Sep 18, 2010 at 8:36 PM
    4x4Runner
    Drunken Sailor
    Yes and it's way easier to drop both than just the front one and try to re-assemble them.
    I usually keep the two attached and drop both together.
  15. Sep 18, 2010 at 8:50 PM
    malander
    max
    01 limited trd 4x4
    good idea may work on it tomorrow
  16. Sep 18, 2010 at 10:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There is also a hook on the front that will keep the front skid from falling off completely after the 3 front bolts are removed. You have to kinda lift it off the front crossmember and slide it back a liitle bit to get it off.
  17. Sep 19, 2010 at 6:35 AM
    trdracing5
    Elizabeth City, NC
    1995 Tacoma 4X4
    5 bolts. Take them off and it will fall a little bit. It will still be held on in the front. Pull on it a little bit and all of it will come off. Piece of cake.
  18. Sep 19, 2010 at 7:33 PM
    davestaco
    David
    Schofield Barracks
    7 bolts........i swear i only had 5....damn it now i gotta go check
  19. Sep 19, 2010 at 7:57 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Sounds like you may be overlooking the two that you have to get to with an extension.
    I rarely have an issue but if it doesn't want to slide of the rear section, it helps if you just loosen the two bolts for the rear section. No need to remove the rear section entirely if you don't need too.
    Also when you put it back on, be sure the thread all the bolts in by hand before tightening them down.
  20. Sep 20, 2010 at 8:40 AM
    davestaco
    David
    Schofield Barracks
    i never had to use a extention to get my skids off.....i just took all the skids off and painted them...gettin ready to take them down and do it again......stupid rust
