Skid Plate With Diff Drop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gJesus1911, Jul 8, 2025 at 9:11 AM.
  1. Jul 8, 2025 at 9:11 AM
    gJesus1911
    gJesus1911 [OP] New Member
    Jesus
    Taco
    King Suspension
    Hello all new here bought a truck with a King Suspension already installed. However it has a diff drop I wanted to know what proper hardware will be needed to add the TRD skid plate. Thanks in advance.
    2017 Tacoma TRD Off Road
  2. Jul 8, 2025 at 9:17 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    You'll probably be able to install the skid with the diff drop, but if not the easiest solution is to lose the diff drop since it isn't really necessary. If your lift is <2.5" (which it probably should be) you'll be fine without the DD.
  3. Jul 8, 2025 at 9:29 AM
    gJesus1911
    Jesus
    Taco
    King Suspension
    I believe the lift is 3 inches or close to 3 inches do you think removing the diff drop would still be ok?
  4. Jul 8, 2025 at 9:32 AM
    BabyBilly
    Billy
    2020 TRD
    You could always reduce the preload on the Kings to drop the lift down a little. Lift on an IFS suspension will reduce your down travel so it's best not to max it out in any case.
    If you do want to keep it at 3" and remove the diff drop look into the boot slide mod. You only need to do the inner CV boots and it keeps the fins from rubbing each other and ultimately ripping the boots.
  5. Jul 8, 2025 at 12:04 PM
    gJesus1911
    Jesus
    Taco
    King Suspension
    I agree with what you just said I might have to go down a bit to gain the extra travel and remove the diff drop.
    BabyBilly likes this.
  6. Jul 9, 2025 at 2:56 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have a little over 2 inches of front lift with a diff drop as it got my driveline in spec and my TRD skid fits with no issues.
