skid plate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pilipio, Oct 24, 2022.
  1. Oct 24, 2022 at 8:05 AM
    pilipio
    pilipio [OP] New Member
    phil
    2016 tacoma sr5
    does the 2016 have a rear skid plate? i see a front one but the the back one that cover the oil pan.
  2. Oct 24, 2022 at 9:43 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    What model Tacoma do you have? Only the Off Road had the skid plate you are referring to. You can add it. All the mounting holes are there to bolt it up.
    Otterstuff likes this.
  3. Oct 30, 2022 at 1:22 PM
    pilipio
    phil
    2016 tacoma sr5
    i have 2016 tacoma sr5 double cab. do you know anyone who have a used rear skid plate to sell. thank you for the info rolled93.
  4. Oct 30, 2022 at 1:24 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I have the original skids from my 2016 off road model collecting dust. Where are you?
  5. Oct 30, 2022 at 1:25 PM
    pilipio
    phil
    2016 tacoma sr5
    I am in atlanta GA
  6. Oct 30, 2022 at 3:35 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    There isn’t a rear one on my 17 OR.
    All mine had was that thin splash guard, def not a skid by any means and the plastic one on the gas tank.
    I bought the rci full aluminum set, engine to transfer case and also the gas tank skid.
  7. Oct 30, 2022 at 3:44 PM
    pilipio
    phil
    2016 tacoma sr5
    thank you helix for the info.
  8. Oct 30, 2022 at 4:04 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Sure thing.
    There are a lot of good options that might be just a bit more dollars than the oem splash guard.
    They usually come in three sections, you can get the coverage you want.
    This is the set I have, 3 individual parts.
    Bottom is the oem.
  9. Oct 30, 2022 at 4:47 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The TRD Pro has a 1/4” aluminum skid plate. The TRD off-road has two pieces of thin sheet metal which I don’t think even Toyota calls a skid plate. The others have a single piece of sheet metal that is the same as the front piece on the off-road.
    The TRD Pro skid plate fits on the other trims and can be purchased from Toyota and other places for around $400. There are also numerous aftermarket skid plates made of steel and aluminum.
