Skid Plate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by richiepagano, Dec 29, 2024.
  1. Dec 29, 2024 at 8:44 PM
    richiepagano
    richiepagano [OP] datsilvayoter
    ‘23 Silver SR5 Tacoma 4x4
    and recommendations for a skid plate for a SR5
    200$ budget
  2. Dec 29, 2024 at 8:51 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    What is the extent of protection needed? Serious rock crawling, bouncing up and down on a sequence of boulders? Or just under-engine protection from forest-gravel roads and parking-space-dividers at malls?
    $200 only realistically buys a used TRD Pro off FB or TW ... not good for off-roading-big-boulders but reasonable for easier-flatter off-roads. $400 gets a good steel from RCI that has protected me from boulders on trails that would have damaged the engine.
    Tocamo likes this.
  3. Dec 29, 2024 at 8:55 PM
    richiepagano
    mostly needed for mudding and trails
  4. Dec 29, 2024 at 8:58 PM
    RichochetRabbit
  5. Dec 29, 2024 at 9:01 PM
    richiepagano
    Gotcha, saving up will probably be best
    https://www.amazon.com/dp/B0D9QCB388
    how about this if i want to go for that TRD look
  6. Dec 29, 2024 at 9:04 PM
    RichochetRabbit
    Go for "quality". OEM TRD Pro is aluminum, not quite as as strong as steel, but 3.4 in thick. RCI or CBI for real steel that can take a serious hit instead of your engine taking the hit.
    Again ... $100 saving and keep the "looks" is not worth the savings. Skip Starbucks for 2 months ...
  7. Dec 29, 2024 at 11:43 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    not going to happen
    BillF1564 likes this.
  8. Dec 30, 2024 at 2:08 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    Realistically $300-$400 is what you will spend for a good skid (engine only). The only way you will find one for $200 or less is on Marketplace or some other reseller site. It's possible if you're patient, but by then you could probably just save up a bit more for an RCI or TRD Pro skid. Thick aluminum is fine for light offroading but steel is the way to go if you really need bulletproof protection.
    richiepagano[OP] likes this.
  9. Dec 30, 2024 at 6:07 AM
    TailHook
    TailHook Oh, what shall we do with a drunken sailor?
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    - Steel can be bent back easily with a BFH, aluminum not so much
    - Aluminum sticks, steel slides
    - Aluminum is more expensive, steel is [obviously] heavier
    Pick your poison for your application...
  10. Dec 30, 2024 at 6:12 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Like mentioned if you can get a good used Off Road plate, your good to go for forest trails, and mud. If your were serious about rock crawling, you need a lot more armour under the rest of your truck too, not just a skid.
    Good luck Richie
  11. Dec 30, 2024 at 6:34 AM
    Livefree1
    Livefree1 Member
    Greg
    2012 Tacoma
  12. Dec 30, 2024 at 6:47 AM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I have that one. The aluminum quality itself seems fine, but I wish I saved up for the TRD. Had to adjust the holes to get them to line up with the truck. It was a huge pain in the ass to crawl under the truck, find the next point of bad fit, get out from under it, modify the hole, get back under, rinse and repeat. Also, the supplied hardware seems crappy and it was really hard to avoid cross threading.
  13. Dec 30, 2024 at 6:51 AM
    Livefree1
    Livefree1 Member
    Greg
    2012 Tacoma
    You can also use the stock aluminum skid off of a 2nd Gen TRD OR. It fits the 3rd gens. Had a buddy use my old one on his 3rd gen
    Tocamo likes this.
  14. Dec 30, 2024 at 8:04 AM
    Zeptiix
    Zeptiix Well-Known Member
    2021 OR Army Green
    Does it have the oil change holes?
  15. Dec 30, 2024 at 8:09 AM
    RichochetRabbit
    Stock OR plate must be dropped to get the filter.
  16. Dec 30, 2024 at 8:21 AM
    Tacoma13_NC
    They look cool but they're not much more than a brush guard. The aluminum is thin and won't protect against anything substantial. I would at least get the heavier gauge aluminum such as the TRD Pro or the RCI like I have in my profile picture.
  17. Dec 30, 2024 at 9:17 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    The Amazon skid plate will work for mild trails. The thing is...mild trails lead to more challenging trails. Eventually you get into a situation where you wish you had bought the proper equipment to start with. We've all been there.
    There is an unspoken policy at TW: We're here to help you spend your money. :spending:
    Tocamo and Tacoma13_NC like this.
  18. Dec 30, 2024 at 10:03 AM
    RichochetRabbit
    The ability to call a stop to going ever deeper into trails you "in your gut" know you do not have the talent, even with the best equipment ... not exactly common here in TW.
    As to "spending other people money ... lines 1, 7-10 in my signature.
  19. Dec 30, 2024 at 1:06 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    To clear up a potential misunderstanding, Amazon does not manufacture skid plates. They allow other manufactures and resellers to sell stuff on their website.
  20. Dec 30, 2024 at 1:08 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Really?! Whoda thunk...:duh:
