Skid plates, hype or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bryan139, Mar 18, 2009.
  1. Mar 18, 2009 at 1:39 PM
    Bryan139
    Bryan139 [OP] I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    What is everybody's take on skid plates? I've heard a lot of guys into offroading say they're just added weight. If your 4000# truck slips in a rut and comes down on an 1000# rock sticking out of the ground it's going to just crease and push the skid plate up into the guts of the truck and you're beat anyway. Opinions?
  2. Mar 18, 2009 at 1:43 PM
    gdctaco
    gdctaco Well-Known Member
    georgetown, ont
    06 access cab 4x4 O/R
    rr diff mod in-cab 110
    ya but would you rather have that 1000# rock slide off your skid plate or off your oil pan?
  3. Mar 18, 2009 at 1:55 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    More about absorbing some of the impact instead of making your truck invulnerable
  4. Mar 18, 2009 at 2:04 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Funny I had that exact same scenario. My 4500lbs truck came off a ledge and hit a 1000+lbs slab of rock. It landed on the skid plate and I didn't know I drove home like nothing happened. I found out 2 days later after I cleaned up and was doing a damage check.
    Without the skid it would have ripped out my transfer case and exhaust.
    Get skids.
  5. Mar 18, 2009 at 2:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
    The skid plate I made for my fuel tank directs the impact away from the tank and to the frame of the truck. Skid plates are designed to take the hit, so something less fragile doesnt have to. 1 hole in an oil pan/tranny/fuel tank can make for a LONG day off roading.......
  6. Mar 18, 2009 at 2:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  7. Mar 18, 2009 at 2:20 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Skids are invaluable. They help direct impact away from the relatively fragile and expensive parts under your truck so that you don't end up having a bad day off road. Also, as a Skid plate, they will help you slide and glide over objects higher than the ground clearance of your truck rather than getting you hung up on things like the cross members. If I had the money, skids would be right up on my list of stuff to add to my truck.
  8. Mar 18, 2009 at 2:23 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Skids + rock sliders if you're gonna take your truck offroad. The protection is WELL worth the added weight.
  9. Mar 18, 2009 at 2:28 PM
    mjp2
    NJ
    I see you're from NJ. Rausch Creek in PA is the best skidplate sales pitch in our area. 1 trip down a trail will convince you of their worth.
    With skids I was able to follow the Jeep through this:
    Without skids and sliders I'd have left my transfer case and driveshaft in that pit and my rockers would have been pushed into the doors.
  10. Mar 18, 2009 at 2:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Jeezus!! Who pushed ya???
  11. Mar 18, 2009 at 2:42 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I'd rather have more protection on my truck than I need than not have any when I need it.
    After suspension first thing I'm doing is skids and sliders.
  12. Mar 18, 2009 at 2:57 PM
    mjp2
    NJ
    The Jeep had a winch. ;)
    Actually made it through with only the help of a spotter. Banged the hell out of the truck and bent my driveshaft skid something fierce, but I pulled out ok. :)
    (And Chris, the blank was from me. I fat-fingered the keyboard.)
  13. Mar 18, 2009 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!! I do that often! Thanks! :)
  14. Apr 12, 2009 at 12:12 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    word; I just completely destroyed my cheap tin can skids under my truck blazing a trail and hitting a rock. It hit hard "BAM" with a little 'ting' sound in there but it glided right over. My alignment is now off, but I'm sure it saved me not to mention if I was 2.5" lower to the ground I would have really ate it.
  15. Jan 20, 2010 at 10:06 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Skid plates aren't hype. Even the crappy factory ones saved me hitting a pointing bowling ball sized rock at speed, as well as debris on the freeway.
    Now its and entirely different question to consider whether or not to upgrade the tin the factory bolts on.
  16. Jan 20, 2010 at 10:24 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not on my tacoma...but I had skid plates all over the frigin place on my Jeep.
    Engine/oil pan skid, gas tank skid, rocker guards, front & rear bumpers....you name it. And those skids were used HARD. They shouldn't be called 'skid plates' - but more like BASH PANS or BASH protection.
    You land on a rock pretty damn hard and WHAM!! But you know...you landed on the skid plate. You can rest and keep wheelin.
    Skid plates aren't all created equal. There are LAME ones out there that don't do anything but waste your money. If you get skid plates, make damn sure its a heavy duty one and it'll cost you more but WELL worth it.
