Skid Plates that Work With Diff Drop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015tacoblanco, Jan 18, 2016.
  1. Jan 18, 2016 at 10:37 AM
    2015tacoblanco
    2015tacoblanco [OP] Well-Known Member
    Trey
    Denver
    2015 Trd Off Road Tacoma DCSB
    Icon Stage 2, Procomp UCAs, 285/70 17 BFG KO2, Fuel Mavericks (Black/Machined), Arb Deluxe Bumper, Slee Sliders, Slee Full Skids, Tyger Auto Tonneau, Fishtaco Badge, Weathertechs, Cali Raised Bed Rack, Tepui RTT
    As the title implies, I'm looking for a skid that will work with a diff drop. Are there any that bolt right on, or require only light modification?
    Thanks.
  2. Jan 18, 2016 at 11:20 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Scrat, Unchained 5150 and 12TRDTacoma like this.
  3. Jan 19, 2016 at 6:30 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    ^^^X2 they all work... After you remove the diff drop. They do more harm than good.
    Scrat and Unchained 5150 like this.
  4. Jan 19, 2016 at 6:37 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    The best way I have found to fit a skid plate when a diff drop is to remove the diff drop and throw it away :thumbsup: As stated above, it rotates the diff causing it to not be properly lubed and the internals can be damaged; essentially a $30 part causing $1000+ of damage..makes sense.
  5. Jan 19, 2016 at 7:40 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    I hate when I burn my differential up from driving downhill for too long.
  6. Jan 19, 2016 at 7:46 AM
    DVexile
    Ken
    Yes, I've seen the bad lubrication theory with regards to changing the diff angle and I think it is just that - a theory and maybe not a very good one. The more "real" concern is I believe significantly changing the angle of entry/attachment of the drive line at the rear of the diff while not actually accomplishing much of anything with regard to improving CV angles. So you aren't really fixing the CV angles at all while risking mucking up another part of the drive line and then having to modify your skids or their attachment.
    If there is a concern with CV boot fins rubbing the better solution is probably to just use boots designed for the higher CV angles like SDHQ offers.
  7. Jan 19, 2016 at 9:16 AM
    Justinlhc
    Exactly. There is a post around here demonstrating how much it actually changes the angle and while it's not a huge change, it definitely DOES change the angle of the CV. The driveline angle would be my main concern as well.
  8. Jan 19, 2016 at 9:56 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    I've been lifted for roughly 56,000 miles and the boots have been rubbing the whole time through mud snow rain gravel highway streams dirt and desert and there's barely even a groove worn in them. Yes the boots might last longer if they weren't rubbing but I think there is more chance of them getting torn from debris or just age. Even stock the boots are constantly flexing and every movement is one step closer to a torn boot.
