Skid Plates Thoughts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Mar 2, 2011.
  1. Mar 2, 2011 at 1:59 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I will be fabricating skid plates for my taco. Thoughts on material thickness. Im thinking 3/16" or 1/4" steel. Also thinking about using stiff rubber 1/2" bushing on each mounting bolt between plate and frame. As always imput and criticism is appreciated.
  2. Mar 2, 2011 at 2:38 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Shop skids on mfg's sites to see what they do, and go from there.
    Hard rubber spacers sound like a good idea. Soft ones would compress and allow the bolt head to be sheared off.
  3. Mar 6, 2011 at 7:01 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    these guys copied AP
    I copied them
    used 3/16
  4. Mar 8, 2011 at 2:28 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Thanks for the sweet hookup brother. I appreciate it .
  5. Mar 8, 2011 at 2:49 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    any added weight to your truck will decrease gas mileage and thats important when gas is heading for $5 to $7 a gallon
  6. Mar 8, 2011 at 3:00 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    You are absolutely correct although I will sacrifice a little gas milage to protect my investment.
