Skid Plates - Who and What: for less corrosive than steel??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by troy28, Jun 14, 2012.
  1. Jun 14, 2012 at 9:47 PM
    troy28
    troy28 [OP] Well-Known Member
    Capitol of Salty Roads
    Need help
    I have read pages of post from my searches here but have not really found a great direction for what I am looking for. Any suggestions, directions, or feedback is greatly appreciated!!
    Truck: 2012 DC LB
    If I get off road it is more of a cornfield/existing trail. I do not need plates that can with stand being smashed into and dragged across rocks on a regular basis. If I do accidentally catch something I would like it to protect the truck for a couple hits. I do like to play in deep snow. I also hope it will stave off catalytic converter thieves.
    My two hang ups with regular steel is its ability to easily rust (very salty roads) and it's weight. I like the idea of Aluminum or maybe a stainless steel. (I know they also will corrode just usually takes a little longer)
    I would like to plate from in front of the bottom of the radiator back past the transfer case.
    Why & What material and company do you recommend? Any personal experience/pics?
    Thank you for your help!
  2. Jun 14, 2012 at 9:50 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Aluminum also corrodes in the presence of salt.
    Ask any salt-water sailor with an aluminum mast about what happens where fittings are attached.
  3. Jun 14, 2012 at 10:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This , I'm on my second set of factory Sport alloys and these ones are already bubbling too
  4. Jun 15, 2012 at 5:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Steel does rust easily but, if taken care of, properly prepped and painted recoated to cover trail damage, it'll hold up just fine. Plus, steel is relatively flexible as opposed to aluminum which is much lighter weight but tends to crack rather than dent.
    Stainless would be an option but, if you're going to spend the money, go high grade. I've got 309 stainless steel side bars and they've held up great for the last 5 years.
  5. Jun 15, 2012 at 9:24 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Eric at Relentless Fab makes aluminum or steel skids from IFS to t-case (t-case only in steel though).
  6. Jun 15, 2012 at 9:40 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Just get steel and be done with it. just about every one makes 3/16" skids.
    If your not scrapping it like you said you wouldn't you will have no issues once you paint them.
    After 2 years in the salt belt getting beat up my skids are fine. At this rate it would take them 30 years to have any rust caused structural issues.
    I would be far more worried about your frame then skid plates. At less then 1/8" thick it will rust away much quicker.
  7. Jun 15, 2012 at 9:42 AM
    XXXX
    sKiP
    05 Prius
    and you can always get them galvanized or strap a anode to them :D
  8. Jun 15, 2012 at 9:45 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    I've never heard of that. Is this common with the factory alloys?
    Frank
  9. Jun 15, 2012 at 9:52 AM
    OZ-T
    Peter North
    British Columbia
    It is here on the coast apparently , the service manager said they are constantly replacing them . They didn't even want to see the old ones on my truck before ordering me a new set under warranty when I called in .
  10. Jun 15, 2012 at 9:56 AM
    Highland Logan
    Frank
    Nova Scotia, Canada
    I'm surprised I haven't seen this on this coast... and with the amount of salt they throw down every Winter too. I'll look into this. Other than taking them off in Winter or frequent washing, is there anything to prevent or slow this? And do you have any pictures of your old ones?
    Frank
  11. Jun 15, 2012 at 10:01 AM
    XXXX
    sKiP
    05 Prius
    Clear coat them yourself and that should help protect them.
    I'm on the East Coast and mine started to bubble as well. I just painted over them.
  12. Jun 15, 2012 at 10:44 AM
    OZ-T
    Peter North
    British Columbia
    Look here
    http://www.tacomaworld.com/forum/showthread.php?t=173667
  13. Jun 15, 2012 at 10:53 AM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    My recommendation is BudBuilt. Bud is great and his stuff is true plate steel. Heavy as hell but they will take an explosion and anything else you can throw at them. I don't live in a salt-rich area so it was never a problem, but just some good maintenance and maybe a once a year cleaning and resealing with a rust-inhibitor-type paint/clear coat should make them last a while. Good luck.
  14. Jun 15, 2012 at 11:01 AM
    mentello
    mentello Member
    California
    09 TRD off road 4x4
    old man emu heavy duty suspension kit, Budbuilt skid plates, B.A.M.F. sliders
    Call Bud....he is very knowledgeable. He makes them in 3/16", 1/8", Stainless, and Aluminum.
    He is the owner of Budbuilt.
  15. Jun 15, 2012 at 11:08 AM
    mentello
    mentello Member
    California
    09 TRD off road 4x4
    I forgot to mention that I had the 3/16" steel on my prior hunting rig (a 99 4runner) and will be ordering another set for my new Tacoma. I may actually try the 1/8" this time. I really like the Budbuilt skids.
    Before install prime and paint with rustoleum industrial grade (both sides) and you should be fine.
    When I had the 3/16" I made several trips across the salty NV desert dry lake beds and struck a few rocks. Within a few weeks I saw rust appear where I impacted rocks. I used a wire brush, primed and paint the spots and it was all good. The frame accumulated way more rust then the skids.
  16. Jun 15, 2012 at 3:02 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
  17. Jun 15, 2012 at 3:08 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Just go with steel, as long as you do the prep and paint right you'll just need to paint the underside. You can also rhino line the non exposed side, and prime and paint the exposed side as to not worry about rust getting under the rhino coating.
  18. Jun 16, 2012 at 6:26 PM
    troy28
    Need help
    Thank you for the feedback and information!!
    What is this magical anode you speak of?
  19. Jun 16, 2012 at 8:11 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Cathodic Protection.
    Frank
  20. Jun 19, 2012 at 6:34 PM
    troy28
    Need help
    Did some calling around today on the Skids. I got a couple suggestions to do SS for the front skid. Then do AL the rest of the way back. They said this would still give me strength up front if there were ever an impact. Then the AL would help with not adding so much weight. Finally the whole package would provide a few extra years over the regular steel till I really had to pull them and repaint them.
    Any thoughts if this would be a good way to go?
    Anyone running AL or SS in a high salt area?
