Skid Plates: yes or no
Discussion in 'All Terrain Vehicles' started by CorrosiveTendency, Oct 30, 2011.
  1. Oct 30, 2011 at 11:34 AM
    CorrosiveTendency
    CorrosiveTendency [OP] When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I have a Kawasaki KFX400 with only the factory plastic skid pieces on it. I do ride some rocky terrain, but I'm wondering if it's worth it to run A-arm, belly and swing arm skids. I know they will help limit damage, but they also create a lot of extra places to hold mud, dirt and snow. Short of removing them after each ride. So my question; are they worth the investment? I think I am going to be putting a belly skid on regardless. But a-arms and swing arm? Thoughts?
  2. Oct 30, 2011 at 11:36 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    swing arm and belly skid is a necessity if you ride in rocks. If you dont do a swingarm skid, you run the risk of deforming or breaking the plastic one, and getting stuck on a trail with a bent rotor or bent sprocket.
  3. Oct 30, 2011 at 11:54 AM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Point taken on the bent rotor/sprocket. I just don't want to be 100 lbs heavier by the end of the ride from mud and snow stuck in all the skids.
  4. Oct 30, 2011 at 1:17 PM
    RelentlessFab
    Eric
    You won't end up that much heavier. Between the engine and belly skid, theres not that much room for stuff to collect between. Usually on the swingarm skid theres a cutout for stuff to drain away from around the shock linkage, and nearly nothing can hold around the rotor and chain/sprocket guard areas either.
  5. Oct 30, 2011 at 3:29 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    So when did you make the move? You used to be in OR. weren't you?
  6. Oct 30, 2011 at 7:18 PM
    RelentlessFab
    Eric
    yeah just moved in June. Lived in Oregon 19yrs.
