Skidplates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spoonman, Sep 25, 2014.
  1. Sep 25, 2014 at 12:11 PM
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Alberta
    I have an Allpro front skid, and The rest are home made. I need to replace those home made skids with something stronger. I have duel cases as well which limits me to a bud built skid for that. So I will be forced to run the bud built tcase skid, and the mid skid will be too long and not mate up to my allpro skid. Why don't I just run all budbuilt? Well I don't like the budbuilt ifs front skid. It has a flat front and I need a angles front to slide over shit. Also it covers the alignment tabs.
    So. What is out there that will mate up to a budbuilt dual tcase skid? Does anyone know?
  2. Sep 25, 2014 at 12:23 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Why not make another set of skids yourself? I made a mid skid that attaches to my all-pro. The design could easily be extended to protect a second case.
    Mid skid build
  3. Sep 25, 2014 at 1:37 PM
    Spoonman
    Jamie
    Alberta
    I made a complete set from the ifs back. I don't have the tools to bend them. Bending the edge makes then rigid, because I didn't bend the edge, they got bashed in good on my last trip
  4. Sep 25, 2014 at 1:41 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    You can always score the plate with your grinder, bend the lip, and then weld it in place.
  5. Sep 25, 2014 at 5:47 PM
    tweeek
    tweeek Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    X2 this is what I did on my bumpers. Certainly more work than a brake, but works. Just fill the gap with weld and grind.
  6. Sep 25, 2014 at 6:52 PM
    Spoonman
    Jamie
    Alberta
    Well let's assume Im not gonna do that!
    Any idears? How far forward does the bud tcase skid go? Anyone?
