Skids for TRD Sport 20'
Discussion in '3rd Gen. Tacomas (2016-2023)' started by caitlin739, May 27, 2020.
  1. May 27, 2020 at 3:20 PM
    caitlin739
    caitlin739 [OP] Active Member
    Caitlin
    TRD Sport
    Hi Everyone!
    I'm currently researching skids. What are ya'll using? I'm just starting my search on 3/16" steel skids that will cover the front, transmission, transfer case, gas tank and differential.
    Any advice you can offer me would be appreciated!
    Junkhead likes this.
  2. May 27, 2020 at 3:20 PM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    Rci metalworks is pretty good. They are a vendor here on TW. Victory4x4 is pretty good too.
  3. May 27, 2020 at 3:21 PM
    caitlin739
    Caitlin
    TRD Sport
    I came across them during my search! I'll refer back. Thanks!
    Catfish21 likes this.
  4. May 27, 2020 at 3:26 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    It depends on your needs overall. Steel is heavy but protects well. You can get aluminum to save a bunch of weight, not worry about rust, and still effective at protection. It will cost a little more and won’t protect as well as steel, but if you don’t intend to bash them often, it’s a good option. Also consider sliders
  5. May 27, 2020 at 3:31 PM
    caitlin739
    Caitlin
    TRD Sport
    I really don't know what my needs are... I'm just getting into offroading, I was always a passanger (ha). I took her out to Jawbone, CA and the surrounding desert. We only hit a rock on the bottom of the frame once, but I was barley dipping my toes in the water. I think I want solid protection underneath because knowing me I'll get myself in an "oh crap" situation. Rock silders are next!
  6. May 27, 2020 at 3:36 PM
    Catfish21
    Stockton, Ca.
    Yeah just go Steel. Better safe, than sorry. Vehicle damage is pretty expensive.. not to mention if you do crack a differential... or the mid case... even your LCA’s.. its all relatively expensive. Armor pays for itself!
  7. May 27, 2020 at 4:04 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Welcome to TW!
    I also vote on RCI. I don't have it yet (I don't go over rocks, mostly mountain runs), but I do like how there is an access panel for the oil filter so it's on my list, just not priority.
    I don't like having to remove the skid plate every time I have to change the oil filter.
    Don't forget that steels are heavy and your front end will start dropping the more weight you add.
    Catfish21 and Junkhead like this.
  8. May 27, 2020 at 4:34 PM
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    +1 for RCI stuff. They're local-ish to me so there's some savings on shipping. I only have the front skid and sliders for now but I can tell you that stuff works real well. Bone chilling hits to the skid. The type that you feel through the cab and in your bones type of hit. Got out to check the skid and it just scraped off some paint. I think the aluminum vs steel argument for saving weight is a moot point. I asked for the total weights of RCI's full steel skids vs aluminum and the difference was 44 lbs. I'm pretty sure I have a tote of camping crap in my bed that is more than 44 lbs.
    Not having to worry about respraying the hits is nice though. I've still yet to crawl under the truck with a rattle can. Should probably do that soon.
  9. May 27, 2020 at 5:01 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
  10. May 27, 2020 at 6:51 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    if your within this area, this is an awesome deal https://www.tacomaworld.com/threads/2016-2020-arb-skid-plate-used-cheap.668364/
  11. May 27, 2020 at 6:59 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Sliders before skid plates.
  12. May 27, 2020 at 7:17 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Aluminum is soft. Steel is hard. I’ve seen 1/4” sheets of aluminum torn like paper. Steel is real.
  13. May 27, 2020 at 8:03 PM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    I run just a TRD front skid on my Taco. No need for more than that.
    Full CBI graces mommas overlander.
    As stated, just comes down to needs/wants
    In&out likes this.
  14. May 27, 2020 at 9:48 PM
    Sharpish
    Brian
    I agree 100% it just sucks to spend quite a bit of money on aluminum skids and tear a big hole into it. Steel will dent and crease if the hit is big enough but it’s still functional after heavy usage and worth something when you take it off.
  15. May 27, 2020 at 10:17 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    As others have said don't neglect sliders.
    Personally I do steel. Aluminum tends to crack and tear on rocks. Just know what you are gonna be seeing the most and decide. Sounds like alot of rocks.
    Steel dents and slides. Plus a BFH can push large steel dents out.
    Check out your local shops in the area. California has some good armor shops. Neighboring Nevada has @RelentlessFab and california has @JLee from Bay Area Metal Fab. Snagged sliders on the cheap and got a front skid too. Working on either getting the mid and t case from BAMF or change to a thinner bolt on solution.
    Jasonstacoma likes this.
  16. May 29, 2020 at 6:11 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I have steel. I smack the underside of truck quite a bit when offroading. I scrape my skid plates more than my sliders, but depending on your terrain and what you do, YMMV.
    In&out and Jasonstacoma like this.
  17. May 29, 2020 at 6:50 AM
    jmauvais
    NorCal
    ...stuff
    most of my trips are desert runs, aluminum is perfect for me. When I hit the mountains, I choose my lines more cautiously but aluminum is all I need
    In&out[QUOTED] likes this.
  18. May 29, 2020 at 6:52 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    I picked up the RCI Skid Trilogy and love them. I got mine in aluminum and they have held up very well. I love how easily I can change the oil without pulling the skids off.
    In&out likes this.
  19. May 29, 2020 at 7:07 AM
    SubCultureNM
    SubCultureNM Well-Known Member
    Brian
    Houston, TX
    2017 DCSB
    I'd recommend the full set from Bay Area Metal Fab. They're heavier duty than just about any other set out there, and the cost is very reasonable for what you get. We run Pelfrey front and mid skids on my wife's Tacoma, with the BAMF t-case skid; had I known then what we know now (about skid construction and company rep) we'd be running all BAMF. Their gas tank skid is next on our list.
    Also, remember that yes, total weight matters, but the weight of steel skid plates will be below your center of gravity, which will actually help the truck feel more stable.
  20. May 29, 2020 at 8:14 AM
    Sharpish
    Brian
    I’ve wrecked a couple front skids. Aluminum does tear and you can easily punch big holes through it.
    In your case that picture shows you don’t abuse your truck off road, and I’m sure the aluminum PRO skid will last a long time.
