Skip shift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Firn, Sep 23, 2022.
  1. Sep 23, 2022 at 4:14 PM
    #41
    tstack22
    tstack22 Well-Known Member
    Arizona
    '22 TRD-OR 6MT
    It can’t be brake checking if you don’t hit the brake.
    But seriously, you’re of course right; don’t downshift (or brake check) when being tailgated.
    tonered[QUOTED] likes this.
  2. Sep 23, 2022 at 5:48 PM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
  3. Sep 23, 2022 at 6:18 PM
    #43
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 6 speed started on the V6 in 2005.
    Horseshoez[QUOTED] likes this.
  4. Sep 23, 2022 at 7:13 PM
    #44
    walleye_slayer
    walleye_slayer Active Member
    This is the beauty of a MT. You get to pick the gear not some programmer.
    Skip shift away when appropriate.
    StandardTaco and shakerhood like this.
  5. Sep 23, 2022 at 7:21 PM
    #45
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If I skip any gear, it would only be 5th but usually I use it briefly. For passing I’ll go 6-4 or 6-3. I only really use 5th for cruising amongst a bunch of cars at highway speed where I may still need some moderate get-up-and-go without shifting.
  6. Sep 23, 2022 at 7:24 PM
    #46
    BLtheP
    Plano, TX
    Cruising highway at 1500-1800 rpm would be damn terrible in a manual. You’d have to downshift constantly.
  7. Sep 23, 2022 at 7:47 PM
    #47
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I drive a manual transmission, but I've been a programmer off and on for most of my life; does that mean my car has an automatic transmission?
  8. Sep 23, 2022 at 7:51 PM
    #48
    Horseshoez
    Dale
    Maryland
    ^ This! ^
    My wife and I have owned over 30 manual transmission equipped cars throughout the years and there has never been one which ran much below 2,500 RPMs at 75 mph; some, like my 1970 Challenger 4-Speed turned 3,750 RPMs at 75 mph.
    BLtheP[QUOTED] likes this.
  9. Sep 23, 2022 at 7:59 PM
    #49
    BLtheP
    Plano, TX
    Yep! My Frontier ran about 2100 at 70. Hated using 6th gear and it didn’t really get better mileage in 6th than 5th. It had no power in 6th. The only benefit was less noise, that specific motor made way more noise at 2500 rpm than below 2500. Anyways, I regeared that one to 4.56 from the stock 3.692 and it was a freakin rocket. Slightly worse highway mpg but so so so much more fun to drive. With 4.56 70/75/80 were about 2700/2900/3100.
  10. Sep 24, 2022 at 8:27 PM
    #50
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    If you need to ask, maybe you need an Automatic??
    Just kidding.
  11. Sep 24, 2022 at 8:35 PM
    #51
    Firn
    Firn [OP] Well-Known Member
    White OR
    I didn't ask for the answer, I asked for the conversation.
  12. Sep 24, 2022 at 8:39 PM
    #52
    Bishop84
    Bishop84 Well-Known Member
    My dad hates when I used to own manuals and blip down to 3rd to pass.
    Never skipped an upshift, but I've never owned a 6 speed.
  13. Sep 24, 2022 at 9:02 PM
    #53
    Firn
    White OR
    I will occasionally skip on the upshift. Mostly on on-ramps where first and second were used to get up to speed and not it's just mixing with traffic.
  14. Sep 24, 2022 at 10:22 PM
    #54
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    All the time...mostly down 6-4 and 4-2, but 3-5 up once in awhile. I'm lazy and don't use the clutch going up much past 3rd either :notsure:
  15. Sep 25, 2022 at 4:22 AM
    #55
    ConantTaco
    Dave
    I was just kidding remember?
  16. Sep 25, 2022 at 5:52 AM
    #56
    InThePlains
    InThePlains Well-Known Member
    I haven't used 5th in many many months. I wish it has taller 6th to get better mpg on the highway.
    With the E15, I'm getting barely 17mpg, used to be 18+.
  17. Sep 25, 2022 at 5:58 AM
    #57
    Firn
    White OR
    And i forgot to put a smiling emoji in, sorry. My comment was in fun, not spite.
    :bikewheelie:
  18. Sep 25, 2022 at 6:06 AM
    #58
    Horseshoez
    Dale
    Maryland
    Pretty good bet a taller 6th would yield worse fuel economy.
    BLtheP likes this.
  19. Sep 25, 2022 at 6:25 AM
    #59
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    I skip from 4 to 6 all the time... 7 years same clutch..
  20. Sep 25, 2022 at 7:04 AM
    #60
    Horseshoez
    Dale
    Maryland
    Done right, consistently doing a 4-6 shift won't shorten the clutch's life by even a mile compared to a more conventional 4-5-6 set of shifts.
    BLtheP likes this.
