Skip shift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Firn, Sep 23, 2022.
  1. Sep 25, 2022 at 7:17 AM
    #61
    Firn
    Firn [OP] Well-Known Member
    White OR
    This surprised me in this discussion. There was a lot of comments that implied big RPM differences and now the clutch. If I skip gears it is as smooth going from 4-6 as it is from 4-5, 5-6, or even 2-3.
  2. Sep 25, 2022 at 7:35 AM
    #62
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    The only manual shift car I've ever had which frequently exhibited a shorter clutch life was an old Plymouth with a 318 V8 and a "3 On The Tree"; the spacing between the gears was so wide there was virtually always clutch slip when moving between 1st and 2nd when accelerating aggressively (I use the term loosely) and sometimes even between 2nd and 3rd. At one point I was replacing the clutch every 20,000 miles; which didn't make me a happy camper.
    Firn[QUOTED][OP] likes this.
  3. Sep 25, 2022 at 8:52 AM
    #63
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Only reason I’d appreciate a taller 6th is so I can still stay in the same spot when I regear. I like 6th where it is.
  4. Sep 25, 2022 at 10:38 AM
    #64
    Big Red 2nd Gen
    Big Red 2nd Gen Well-Known Member
    Dan
    Red 2008 TRD Access Cab 6 Speed
    TRD Cold Air Intake, Fat Bob's Vated Bilstein fronts set at 3 inches, stock rear leafs with ICON progressive multi leaf "add a leaf", MBRP Stainless dual exhaust, Sport Hood with scoop, Pedal Commander, Pro Comp 16x8 wheels with 265/75R16 KO2's, toneau cover.
    Depends on the situation but I usually skip a gear or two up or down.
  5. Sep 25, 2022 at 1:44 PM
    #65
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    A taller gear probably wouldn't help the mileage, these engines don't care for lugging.
    Speed is a mileage killer with these trucks, over 65 and the mpg really drops.
