Skip Trans Temp Check Mode?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josh-L, Feb 11, 2024.
  1. Feb 11, 2024 at 1:44 PM
    Josh-L
    Josh-L [OP] Well-Known Member
    2021 Silver SR DCSB V6 4x4
    What’s the purpose of putting the truck in temp check mode after a drain and fill for the transmission? Can I just take out the overflow plug and let out the extra or do I have to do the temp check mode process?
  2. Feb 11, 2024 at 1:57 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    to make sure you arent overfilled when trans gets to temp. If you are going to do to might as well do it right?
    Big tall dave and Chew like this.
  3. Feb 11, 2024 at 1:57 PM
    Koolbreeze7
    Jon
    Jersey
  4. Feb 11, 2024 at 2:47 PM
    Josh-L
    Thanks!
  5. Feb 11, 2024 at 2:53 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    DONT skip the temp check before draining…
    eurowner likes this.
  6. Feb 11, 2024 at 2:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The trans fluid apparently has a high rate of thermal expansion. If you take out the overflow plug outside the designated temperature range, the resulting fluid level can be too high or too low.
    Koolbreeze7 likes this.
  7. Feb 11, 2024 at 2:58 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Liquids (plus pretty much all matter) are different volumes at different temperatures.
    Pulling the overflow plug when you are in temp check range ensures that you are measuring the correct amount of fluid.
    That said, I use an OBD reader to my phone and pull the plug when it's within range. That's much easier than using the jumper method.
    faawrenchbndr likes this.
