Skipping gears with a Manual Transmission
Discussion in 'Technical Chat' started by dcquin31, May 27, 2010.
  1. May 27, 2010 at 1:20 PM
    dcquin31
    dcquin31 [OP] Member
    Hawaii
    2017 TRD Pro
    On my way to and from work, I try to conserve on gas... a friend of mine said that I could skip gears since I have a 6 speed manual. So lately I have been shifting from 1st to 2nd to 4th and then 6th... skipping 3rd and 5th all together. The roads here in Ohio are flat and the truck doesn't seem to Lug or anything. Just wondering if I can mess anything up by doing this? Thanks!
  2. May 27, 2010 at 1:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You wont hurt a thing :)
  3. May 27, 2010 at 1:21 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    No it wont hurt anything. I do it all the time to.
  4. May 27, 2010 at 1:22 PM
    BassPilot
    BassPilot Well-Known Member
    Bennett
    Bay Area, California
    2010 DC 4X4 TRD Offroad manual
    TRD Cold Air Intake, TRD Cat Back, 5100's, TSB
    I do this all the time, I'd also be interested in any issues with this
  5. May 27, 2010 at 1:25 PM
    dcquin31
    Hawaii
    2017 TRD Pro
    Great... I didnt think so, but just wanted to check with you guys. Thanks!
  6. May 27, 2010 at 1:26 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I drove a buddies car before that was a manual and I would almost always go from 2nd to 4th gear
  7. May 28, 2010 at 8:58 AM
    Simms65
    Simms65 Well-Known Member
    David
    WV
    '16 Quicksand O/R M/T
    I drive 2-4-6 most of the time, unless the speed limit dictates another gear (30-35mph, I use 5th).
    I do run through the gears overall on average, but from a dead stop it is 90% 2-4-6.
  8. May 28, 2010 at 9:01 AM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    I'm pretty sure you should be fine, I do it myself. :thumbsup:
    Now not to thread hijack or anything but i am kinda curious about one thing.
    What does actually do to gas mileage?
    ex: is it less efficient to be in 6th gear at 35mph or 4th? does shifting when the RPM's are too low hurt your gas mileage?
    may be a stupid question but i gotta ask haha
  9. May 28, 2010 at 3:57 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Wont do a damn thing for mileage, but I have skipped on all my vehicles. Just make sure you match the revs for whatever gear you want.
  10. May 28, 2010 at 4:11 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    skipping is just situational. sometimes its just annoying to have to go through a gear when you can "skip" it.
    As for mileage, I drive the same 40 miles every day for work. I have been tracking my fuel consumption right down to each 1/4 of the tank. I've always wanted to know how many miles i most likely have even if i'm sitting at a half tank or 1/4 tank.
    I have tracked the high and low #'s as well as the average for each 1/4 of the tank. I have found that you should keep in beween 1500 and 1800 and you'll get the best mileage. when shifting up, never let it go past 2000. obviously this is unavoidable on some terrain but when you can keep it there, do so.
    There is also something to say for the idea that sometimes your engine just needs to run and clean itself out. not sure if there is any science to this but i've always heard it.
    I have rhino liner all over my truck, 6" fabtech lift, 305/70/16 tires, sliders, allpro bumper, and a Warn 9.5ti winch. with all that I can still get 17 mpg or more if i ride like this.it only takes goosing it little while before i get into the 16-15 range :) 15 is the lowest ive ever gotten. I know i could get 18 if i was to play it nice for a whole tank but i dont think that is going to happen :)
  11. May 28, 2010 at 4:20 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Keeping your rpms lower than higher will help keep your gas mileage up. With that being said, I suggest everyone only drive in 6th gear, no matter what speed your going. Lol
  12. May 28, 2010 at 5:01 PM
    Tijean
    Tijean New Member
    N. Ont. Can.
    SR5 4WD
    To be able to skip a gear on upshifting means that you have to rev it out a bit further so that when you drop it into the second next gear you wont be lugging it. You havent made any profit on that move unless you were on a downgrade and had gravity working for you.
    Where skipping a gear is of benefit is downshifting where you have braked or a steep hill has slowed your road speed quickly then jumping a gear gives the best engine revs for the road speed.
    The long answer really is it depends on road speed and load; low revs and light throttle is ok but mashing the pedal at 1,200 revs is not. As a truck driver I never liked revving for nothing or lugging. Using the best gear is the easiest on the synchros in the tranny and gives the best mileage.
  13. May 28, 2010 at 6:41 PM
    gjbonner
    Guy
    Northern Idaho
    must remember also that too low of an RPM and you'll be hurting your MPG.
    Oh and i love the staying in 6th gear thing hahaha that's thinking outside of the box!
  14. May 30, 2010 at 8:39 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Not likely, I did a bunch of testing, and the highest gear always, without exception, got the best mileage, even when lugging. The only exception was below 1000 rpm, but engine vibes at that point were the bigger issue.
  15. May 30, 2010 at 8:41 PM
    Isthatahemi
    TRD OFF ROAD
    Oh yeah, and skipping gears does not help economy, it is a convenience thing, that's all.
  16. May 30, 2010 at 8:43 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i used to skip 3rd all the time in my jetta and developed a tremendous grind after about 2 or 3 months of skipping it. then i started going into 3rd and it was hard and grinded like non other...cause?
  17. May 31, 2010 at 6:56 AM
    Barnone
    Barnone Guest
    I think 6 speed boxes in the Tacoma are purely a marketing gimmick.
  18. May 31, 2010 at 7:34 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    IF you know how to "skip" then no problem,if not your "Syncros" will hate you :mad:....progressive shifting is an "art" and can be done, BUT like anything else..."thinking it" and "doing it".. two complete opposites;)..
    My question is,WHY??....5 or 6 speed trans are easy and "fun" to drive....but then again I don't mind moving through 8-18 speeds either :cool::cool:..
  19. Jun 1, 2010 at 6:10 AM
    gjbonner
    Guy
    Northern Idaho
    Please expound...what is there angle?
    Hmmmmm so what youre saying is too low of an rpm can hurt,...right???? wierd, that sounds an awful lot like what i said:facepalm::crazy::smack:
    I would venture to say that it is actually once you get below your engine idle rpm not 1000.
    oh and also when you start getting below your engine idle rpms things start to vibrate like they shouldn't. that cant be good for you either.
  20. Jun 1, 2010 at 2:24 PM
    Isthatahemi
    TRD OFF ROAD
    I would take it as obvious that no one runs less than 1000 rpm on the street, given the vibrations associated with that. I had assumed you meant in the under 2000 rpm range, if you were more clear, than there would have been no mistaking what you where trying to say.
    If your guess is more accurate than my scangauge, yes. Otherwise, from an efficiency perspective, my testing shows 1000 - 1100 to be the point where mileage dips.
