SkyJacker 3inch lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobbittjack, Dec 25, 2019.
  1. Dec 25, 2019 at 4:36 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    You cant lift 2.5 inches without new shocks and struts unless you use blocks which have lots of defects and are not an ideal long term option.
  2. Dec 25, 2019 at 4:38 PM
    bobbittjack
    bobbittjack [OP] Active Member
    Jack
    2002 4x4 Tacoma Double Cab
    ok i’m looking at a guy with 3.5inch fabtech struts and 3 inch rear blocks with shocks, should i buy that
  3. Dec 25, 2019 at 4:40 PM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Like I said rear blocks aren’t ideal and 3.5 inch lift will cause a lot of other issues other then just trying to lift, you’d need to replace a bunch of other things it’d be a big hassle
  4. Dec 25, 2019 at 4:42 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    No. Just no.
  5. Dec 25, 2019 at 4:43 PM
    bobbittjack
    Jack
    Haha someone just link me the sh*t and i’ll buy it! i just want any lift between 2.5-6 haha under $800
  6. Dec 25, 2019 at 4:47 PM
    bobbittjack
    Jack
    How bad is this skyjacker lift? this is where i started
  7. Dec 25, 2019 at 4:47 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
  8. Dec 25, 2019 at 4:55 PM
    bobbittjack
    Jack
    Any more? this is complicated :fingerscrossed:
  9. Dec 25, 2019 at 4:56 PM
    Dirt Sandwich
    Dirt Sandwich Well-Known Member
    Lago Vista, TX
    2003 DC TRD OR 4x4 Black
    eibach 620#, 5100’s, Icon UCA’s, 285 KO2’s TG lopro bumper, car seat
    285’s will likely rub even with a 3” lift.
    I have a 3” toytec lift with Bilstein 5100’s all around. (Much like everyone is recommending) I have Icon UCA’s and I just switched from 255/85/16 with no rub to 285/75/16, which rub kind of a lot. I need to do the “pinch weld mod” and you will need to as well. Keep in mind, with 3” of lift, you will also need upper control arms, (for alignment) and high angle CV boots, or perform the boot slide mod. Don’t get discouraged, but be armed with knowledge before you spend any money. If I had made a list of all the crap I would need to buy (and do) to make a 3” lift work properly, I probably would have waited until I could afford to SAS it. 3” doesn’t seem like much, but it takes a lot for these trucks to be done “right”
  10. Dec 25, 2019 at 5:00 PM
    Matic
    Tricky Dick
    Easley, SC
    I mean, you have 12 posts.
    You should know by now.
    bobbittjack[OP] likes this.
  11. Dec 25, 2019 at 5:00 PM
    Dirt Sandwich
    Lago Vista, TX
    Also, Sweet truck!! Welcome to TW, and good luck with your lift!!
  12. Dec 25, 2019 at 5:01 PM
    bobbittjack
    Jack
    Wow! anyone want to buy a 2002 tacoma 4x4 Double Cab
  13. Dec 25, 2019 at 5:03 PM
    Dirt Sandwich
    Lago Vista, TX
    YES THEY DO!!!
    40 more posts and you can list it.. lol.
    jk man, don’t get discouraged, people around here are extremely helpful, and just want you to be prepared for what is coming.
  14. Dec 25, 2019 at 5:05 PM
    bobbittjack
    Jack
    I’m loving this help... got this truck for $3400 and wanted to spend less than $500 for a lift originally... looking lot that won’t be the case... already got the tires and rims for a deal! just kinda wanted a simple explanation or lift to buy and put in and be happy, but sounds like i’m driving stock for a while!
  15. Dec 25, 2019 at 5:05 PM
    #35
    eon_blue
    Azusa, CA
    The kit @Blue92 posted is the one to get with the budget you have, it's the best option.
    Even with a lift you will have to trim and flatten the pinch weld to fit 33" tires. Lift only does so much to help with bigger tires, cutting/trimming and flattening are unavoidable depending on your wheels backspacing and alignment numbers
  16. Dec 25, 2019 at 5:08 PM
    #36
    bobbittjack
    Jack
    spacers wouldn’t help?
  17. Dec 25, 2019 at 5:08 PM
    #37
    eon_blue
    Azusa, CA
    Wheel spacers usually make rubbing the pinch weld worse, they will help if you're rubbing the frame though
  18. Dec 25, 2019 at 5:10 PM
    #38
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    If it’s not too hard, go about it by selling your tires you have on your rims and keep the rims, (you can get them removed by a tire shop or something maybe your school has one) then buy some new tires. Here’s a guide to tires and how much bigger they are or how much smaller they are then stock tires. Just enter 31x10.5r17 and click alternative sizes and it’ll tell you everything you need to know especially how much bigger the diameter is compared to stock
  19. Dec 25, 2019 at 5:11 PM
    #39
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Or just keep it stock until you have more money to do this! I’m sure someone on Craigslist would buy the rims and tires off you quickly and you’d have enough to get some different ones that’ll fit better
  20. Dec 25, 2019 at 5:12 PM
    #40
    bobbittjack
    Jack
    Ironically i work at a tire shop so i can go about that!
