SKYJACKER LEAF PACK???????
Discussion in 'Suspension' started by whoward85, Jul 24, 2013.
  1. Jul 24, 2013 at 7:03 AM
    whoward85
    whoward85 [OP] Active Member
    Lee
    Goochland, VA
    08 6-SPEED TRD SPORT DC SB
    Billies with 2.5" in front and 2" in rear, AFE CAI and TBS, Banks exhuast, LED Interior lights UWS Tool Box, DTRL mod, anytime fogs, UltraGuage
    I saw the skyjacker makes a soft ride leaf pack that is a 1.5 to 2" lift for 209$ are these decent springs or should i go with OME dakars?????
  2. Jul 24, 2013 at 7:09 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I have them. They are about 4 years old now. Still great, flex and ride great.
  3. Jul 24, 2013 at 7:26 AM
    whoward85
    Lee
    Goochland, VA
    Thanks man!! I have 2" blocks right now with Eibach and 5100s up front I have the stupid squeak and I am at 86,000 So i was looking for a cheaper way around the OME and have the same height do you think it will be sufficient?
  4. Jul 25, 2013 at 10:36 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    how much lift did you actually achieve with them do you think?
  5. Jul 26, 2013 at 6:48 AM
    Dark Knight
    Jeff
    NC/SC
    They have settled to about 2" of lift.
  6. Jul 26, 2013 at 6:54 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Important to note that this is on a DCLB, this may equal 2.5" on a DCSB or Access cab.
  7. Jul 26, 2013 at 6:57 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    from what i've read...people with dakars get anywhere from 2.5-3" of lift, so you'll be sitting slightly lower, what if you put a .5" or 1" block and the skyjacker springs? that is if you're trying to match the dakar in height
  8. Jul 26, 2013 at 7:22 AM
    Bearcoatoffroad
    Bearcoatoffroad Well-Known Member
    Barry
    Rincon, GA
    '07 TRD Off Road 4x4 Double Cab
    2.5" spacer lift, Tundra wheels with spacers
    $207 EACH from what I'm reading...
  9. Jan 9, 2014 at 7:14 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Knocking the dust off this thread
    Someone at a friends house was asking about these and I never heard of them. Are they actually full leaf packs replacing the factory ones or just like an add-in using the first spring with the eyelets?
    We have a debate going and most think they are like a multi leaf AAL, but the official answer is a mystery as of now.
  10. Jan 10, 2014 at 1:13 PM
    Dark Knight
    Jeff
    NC/SC
    Full leaf spring replacement. Not a multi-leaf AAL.
  11. Jan 11, 2014 at 3:57 AM
    whoward85
    Lee
    Goochland, VA
    That's what I thought! Any other reviews?
  12. Mar 17, 2014 at 4:13 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Bump this. I would also like to hear other reviews of these leaf packs. thinking of these along with a shackle flip.
  13. Apr 1, 2014 at 8:23 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    Bump
  14. Apr 1, 2014 at 8:26 AM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    do you get any squeaking with theses? im SOOOOOOO tired of the squeak!
  15. Apr 1, 2014 at 8:26 AM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    anyone run these with blocks?
  16. Apr 1, 2014 at 8:33 AM
    slodc4
    Steven
    Winterville, NC
    Locked 17 trd sport
    these are 209 per leaf pack right?
  17. Apr 1, 2014 at 8:36 AM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    I was just looking at these last night, I want to know more about them.
  18. Apr 1, 2014 at 10:20 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    I have some on my truck, they are the 3.5". Little bit too much rake in the beginning but they settled pretty well and sit pretty level with a bit of weight in the bed. They're not bad leaf springs but if i wiggle the wheel back and forth while driving at a decent speed the rear end has a delayed "sway" i guess you could call it. Almost like theres too much body roll in the rear. It could be because my springs are the taller ones...and i mean they are called "soft ride" leaf springs.
  19. May 26, 2015 at 9:54 AM
    toy 2
    toy 2 Well-Known Member
    Dave
    Reno, NV
    just ordered a set myself. on sale for $186. will write a review when I get them installed
  20. May 27, 2015 at 5:45 PM
    NiteTaco
    NiteTaco Well-Known Member
    North Alabama
    09 TRD DCSB
    I installed the same Skyjacker set on my 2009 DCOR about 2 months ago. I have 5100s all around with the fronts set at .85 plus a camper shell and cargo bed slide (about 300 lbs between the two of them). Even with the permanent weight in the back, I still a little over 1.5 in the back and have a nice slight forward rake to it.
    I absolutely love how they ride, but my drivers side developed a squeak about a month ago. Used some wax based motorcycle chain lube which fixed it for a few days, but the squeak is back again. I've isolate it to the driver side spring between the forward clamp and the U-bracket for the brake line mount. I'm going to try lining between the springs in that area with some plastic strips cut from oil jugs this weekend and see how it goes.
    Don't get me wrong...I'm not discouraged by the Skyjackers in the least. Again, I absolutely love the ride. It's that good that I'll either put up with the squeak or keep after it while I "Cadillac" around with my Skyjackers and 5100s.
    If anyone has a solution that they know works on the Skyjackers to fix the squeak, I'd love to hear it.
