SL vs E Rated tires
Discussion in 'Wheels & Tires' started by toyotahenry, Nov 2, 2020.
  1. Nov 2, 2020 at 10:25 AM
    toyotahenry
    toyotahenry [OP] N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    Has anyone here experienced both tire variations on stock suspension setup? If so, how much of a ride difference did you actually notice?
    thank you
  2. Nov 2, 2020 at 3:37 PM
    toyotahenry
    Houston, Texas
  3. Nov 2, 2020 at 3:51 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    Is it noticable yes, do I mind it no.
    The only way to know for sure is to ride in a friend's truck with E tires. Or if you're like me and none of your friends drive trucks ... just take the plunge and hope for the best.
    toyotahenry[OP] likes this.
  4. Nov 2, 2020 at 3:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    A lot.
    Picking the tire for how you use the truck 90% of the time is good for most folks.
  5. Nov 2, 2020 at 3:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    A C-load tire is a good compromise for increased tire strength/durability without ending up with a very heavy stiff riding E-load tire, which will also reduce mpgs and performance.
  6. Nov 2, 2020 at 3:55 PM
    su.b.rat
    su.b.rat broken truck
    if you want a real answer you'll want to provide more info, like tire size, suspension, etc. the oversimplified answer from my highly reactive ass is that sl & c tires ride like bubblegum and should be on a luxury car where you don't want to feel the road. i had them for 51 miles on the drive home from the dealership after getting my truck. E's on the next day. if you run E's under 35psi they soften quite a bit, but that creates more rolling friction and lower mpg. it really depends on the whole package you want in the end.
  7. Nov 2, 2020 at 3:56 PM
    rocky_mountain_dave
    David
    Meh. My toilet is empty 90% of the time, so maybe I should have spec'd my bathroom without one. Or maybe the 10% of the time when I need it, dictates what I choose to buy.
    Different strokes for different folks.
  8. Nov 2, 2020 at 4:01 PM
    su.b.rat
    fully disagree with this unless you are specifically talking about wet, icy, or snowy conditions with a unloaded truck and a shitty driver. my truck's performance is enhanced by running E's, that's actually why i run them, but i guess that's another discussion for later.
  9. Nov 2, 2020 at 4:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Depends on how you define performance. More rotational mass from a heavier tire means slower acceleration, increased braking distance and more unsprung weight.
    ardrummer292 likes this.
  10. Nov 2, 2020 at 4:16 PM
    su.b.rat
    this is true, agreed. but the other side is the whole package, of which the tires are merely a part. if i put SL or C tires on my modded truck, it would slow the thing down terribly. it wouldn't be safe above highway speeds due to the chassis stiffness, because the only real compliance would be in the tires, and those tires couldn't handle the forces at speed. E tires can, and nothing less in my situation, but... not intending to highjack the thread.:boom:
  11. Nov 3, 2020 at 7:41 PM
    FishTaco805
    FishTaco805 Active Member
    P
    2020 Tacoma TRD Offroad 4x4
    Amen.
    Basically more $ overall. Lol
