Slam hood or push it closed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KRUD, Apr 4, 2022.
  1. Apr 4, 2022 at 5:05 PM
    piratepegleg
    piratepegleg Well-Known Member
    Davey
    Texas
    2022 Lunar Rock TRD OR
    Pro grill, leer 100XR
    :rofl::rofl::rofl::rofl::amen::cheers:
  2. Apr 4, 2022 at 5:05 PM
    tacoshell88
    tacoshell88 Not that well known member
    Michelle
    Somewhere along the Mexican border
    2021 DC Cement TRDOF
    Drop it from a few inches above. Pro, it closes. Con, nada.
  3. Apr 4, 2022 at 5:48 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I had a 1989 corolla. I used to drop the hood closed. Then I noticed dropping it caused buckles in the hood every time I dropped it. Yes, the hood was way flimsier then Tacomas today but since then I always push close my hood.
  4. Apr 5, 2022 at 8:03 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Drop it from a few inches. If for some reason it doesn’t catch, then I push it down. As long as you use common sense force, Its not going to dent or break .
  5. Apr 5, 2022 at 8:12 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Drop. 6 inches or so.
  6. Apr 5, 2022 at 11:14 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    I round house kick the hood prop rod.
  7. Apr 5, 2022 at 11:20 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I bought a Toyota so I wouldn't have to deal with these type of issues.
  8. Apr 5, 2022 at 11:21 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I use to do this, then I modded the hood and installed a power opening/closing hood. You know us Tacoma guys have to mod every damn thing on the truck. Next week I'm going to install AI software on it!
  9. Jan 4, 2025 at 2:30 PM
    Derry Murbles
    Derry Murbles Well-Known Member
    SoCal
    2023 CSM TRD OR DCSB
    - Yota Xpedition Pro Style Grill - Yota Xpedition Black Emblem Overlays - Weathertech Bug/Rock Deflector - Cali Raised LED Cat Shields - Cali Raised Bed Stiffeners - Gold Hook Black TRD OR Bed Decals - TRD Pro Style Taillights - FitCamX Dash Cam - AJT Designs Nalgene/Yeti Cupholder - Fumoto F133N Oil Drain Valve
    Not quite a necro bump, but relevant to my question- Anyone’s truck give you little chirps when you drop the hood closed? I have a 2023 Tacoma that hits me with 7 soft horn chirps almost every time I close the hood.
  10. Jan 4, 2025 at 3:02 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    No chirps in 9 years of dropping the hood. Is your truck running or completely shut off?
  11. Jan 4, 2025 at 3:05 PM
    Derry Murbles
    SoCal
    Completely shut-off. After doing some more digging, it’s seeming like the horn beeps may be related to the aftermarket Rockledge Securities alarm “upgrade” and dropping the hood triggers the shock sensor that I believe is installed. I’m trying to find the shock sensor since per the manual, there’s a little adjustment dial that allows you to lower the sensitivity. Want to test that and see if that ends the chirps.
  12. Jan 4, 2025 at 3:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
    No.
  13. Jan 4, 2025 at 3:07 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    My dishwasher plays a little tune when it finishes.
  14. Jan 4, 2025 at 3:14 PM
    TA2016
    Oregon
    I believe I get several chirps closing the door with the engine running and my Fob outside the truck.
    In troubleshooting you might see if your hood chirps and door chirps are coming from different speaker/siren sources or the same sound source. This might help determine if it is a factory or aftermarket chirp. Good luck tracking it down.
  15. Jan 4, 2025 at 3:16 PM
    #35
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Mine does eight chirps seven means it’s not closed all the way.
  16. Jan 4, 2025 at 3:20 PM
    #36
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    RockLobster always has some great replies!
    I have hood struts so I push mine down.
    Prior to hood struts, I dropped it (like it's hot!) from about 5".
  17. Jan 4, 2025 at 3:42 PM
    #37
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Drop and roll............
  18. Jan 4, 2025 at 3:52 PM
    #38
    Derry Murbles
    SoCal
    Found the shock sensor by following the wire off of the LED/button module to a bit further up under the dash. Little adjustable dial was red. Turned it down a couple clicks and no more beeps when dropping the hood.
    Done and done.
  19. Jan 4, 2025 at 3:52 PM
    #39
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I show mine a picture of Chuck Norris and it closes itself
    zacinnc78 and Beerpayzdabillz like this.
  20. Jan 4, 2025 at 4:02 PM
    #40
    Derry Murbles
    SoCal
    I prefer the jingle from the washing machine personally.
