SLAPPING TIME CHAIN
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elyhatto, Jan 22, 2021.
  1. Jan 22, 2021 at 7:46 AM
    Elyhatto
    Elyhatto [OP] New Member
    2019 trd sport tacoma black
    So my 2007 tacoma 4.0l has a loud slapping noise coming from timing chain. Took it all apart only to find one of the lifters was beat to shit and was broken so after replacing the whole timing chain, all lifters etc. noise is still there. Now considering it might be the oil port itself to that exact lifter clogged, going to try blow air through to clean it out. Was wondering if you guys had any similar problems and what your solutions were.
    igno1tus likes this.
  2. Jan 22, 2021 at 3:17 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Don’t know but welcome and hi !
  3. Jan 22, 2021 at 7:23 PM
    Waasheem
    Waasheem
    2007 xrunner
    Maybe this will help. My 96 Nissan pu developed a loud timing chain slapping noise. I learned it’s tensioner uses oil pressure to push out and put tension on the chain. I found someone who sells a kit to replace it with one that has a tiny spring inside. The kit came with detailed instructions, a few different sized little sleeves, and wooden wedges attached to string to cram against the pulleys to keep the chain on. The end result was no more wacking noise and a way better running engine. I thought there would be just a little slop but the chain was unbelievably loose. Different animal I know, but there it is.
