Slashed Tires!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gtdad66, Feb 15, 2012.
  1. Feb 15, 2012 at 7:44 AM
    gtdad66
    gtdad66 [OP] Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
    So apparently some P.O.S. decided to cut two of my tires last night. Damn... so I get out my floor jack and jack stands and take off my tires and off to the tire store. Get there and they have to order the tires and I have to wait several hours, still waiting as I'm typing. All this got me to thinking what if I was on the road and not at home with the tools???? I have a 2010 D.C. short bed with a 3" lift, factory step bars. It is my understanding that a hi lift jack needs sliders or at least better step bars to work for a tire change.. correct? I guess my question is what is best to keep in the truck for a tire change with a lifted truck? any suggestions?
  2. Feb 15, 2012 at 7:45 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    whats best? tha harbor freight racing 3 ton floor jack!
  3. Feb 15, 2012 at 7:48 AM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    To be honest I didn't want to ride around with a floor jack in my tool box if i could help it. the box is pretty full already.
  4. Feb 15, 2012 at 7:49 AM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    that's why i have AAA. best money i ever spent. saved my a$$ many many times away from home.
  5. Feb 15, 2012 at 7:52 AM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    I have AAA but dont want to wait for an hour + if I can help it.
  6. Feb 15, 2012 at 7:57 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    What size tires are you running? My spare is a 245 and im running 285's... So I am screwed anyways...
  7. Feb 15, 2012 at 8:04 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    A piece of 4x4 or 6x6 will do the trick. You can also use a ratchet strap around the axle and frame. This prevents the leaf springs or a-arms from flexing. Make sure it's a beefy strap if you go that way. You don't want it to snap on you.
  8. Feb 15, 2012 at 8:26 AM
    badger
    badger Well-Known Member
    07 SR5
    I guess I don't understand the question :rolleyes: Is the problem that the factory axle jack won't fit with both tires flat?
    I have been using a hydraulic scissor jack similar to this one for years. Mine came with a case and it is very compact and fairly light. It compresses down to 5" but lifts to 15
    http://www.autobarn.net/mvp22lbhydsc.html?site=google_base
  9. Feb 15, 2012 at 8:44 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I think the concern is that the factory Jack is to short to lift a lifted truck high enough. Or that it can't be used to lift the entire front or rear, its designed for lifting only one wheel. Not sure.
  10. Feb 15, 2012 at 8:52 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I had some dikshits do this to a car about 20 years ago. SUCKS. You can only hope the little retards cut themselves some day.
  11. Feb 15, 2012 at 8:53 AM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    I have 265/70/17 tires. The concern is the factory jack is most likely too short to lift high enough to remove a tire with the 3" lift I have.
  12. Feb 15, 2012 at 9:02 AM
    jackhart
    11 DCLB
  13. Feb 15, 2012 at 10:07 AM
    nfs257
    The factory jack with a 4x4 under it will lift my front tires up enough to change them out...
  14. Feb 15, 2012 at 10:31 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It could still limp you somewhere if need be.
  15. Feb 15, 2012 at 10:33 AM
    nfs257
    It already has once. I had a rock go through the side wall off road once... :rolleyes:
  16. Feb 15, 2012 at 10:36 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    I keep about a 6" length of 4x4 in the truck.
  17. Feb 15, 2012 at 10:38 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    if you have a open or e-locker you should be ok with the smaller tire correct?
  18. Feb 15, 2012 at 10:41 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
  19. Feb 15, 2012 at 11:51 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Kinda. The difference in tire sizes makes your spiders "walk" that is to say ordinarily they don't walk(move) while driving straight, only through turns. When theres a difference in tire size in an open differential your spiders work overtime and you can wear them out eventually. With the LSD you're working that LSD overtime as well... Not a good thing to do.
    You'll be okay for a short period with the open. Not sure how long I'd run the LSD like that though, not sure how fragile the clutch discs are.
  20. Feb 15, 2012 at 12:25 PM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Last time I called AAA I was very specific about the equipment required to get my truck out of its predicament. They sent a completely unprepared truck. I was a ways out, too, so instead of 2-3 hours it took about 7-8 to get a wrecker with the proper equipment. I also had to pay that driver $200 out of my own pocket then wait 6 weeks for AAA to reimburse me. AAA is awesome if you stay on the road. Don't plan on calling them for help if you use an OR Tacoma for its intended purpose :)
